Results 1 to 15 of 18
    bullettrain is offline LX Newbie
    Best rear tire for 300SRT8 ?
    Completing engine mods and suddenly have more power than the RSA 245/45/20 's can hook up. I want to upgrade the rear tires for traction, but only use it for street use. Considering Nitto 555r but want the biggest size that fits.
    Going for the sleeper look, so I want to retain the stock 20 x9 wheels. So what tire fits on that rim and under the car.
    Would bigger tires work on wider rims, and is anyone making a repoduction wheel in a wider size than 9 inch. Does the offset need changed?
    Alot of questions, but the goal is to have maximum rear traction with stock wheel appearance. The rear axle will be the 09 challenger rear upgrade. Input?
    Maistro69 is offline Obama SUCKS!!!
    Nov 2007
    Certified liberal hater
    I'm putting the 315/35/20 Nitto NT05's on mine. Having the stock wheels widened 1 1/2" and spaced out to fit. It's really tight but will work
    I'll keep my money, guns, and freedom, you can keep the change.
    bryan_k47's Avatar
    bryan_k47 is online now Support the Oil Patch buy a Hemi !!
    May 2009
    Edmonton,AB
    I love Toyo Proxes 4's myself 275/40zr20
    Maistro 69
    Who is widening your wheels and how $
    Are they having to use spacers between the hub and wheel?
    How thick?
    Need all the details please............Exactly the info i was looking for
    Nov 2007
    Weldcraft will be doing it and I have 2 different quotes. 1 verbal at $265 ea which is ridiculous and an email for $150 or $175 ea (I forgot), a bit more reasonable. They say it's a 3-4 week wait right now From all the measurements I've taken a spacer of 5/16" should give just enough clearance without sticking out of the wheel well at the top, almost even but not protruding. There will be a little trimming of the inner plastic liner but not sure exactly how much until it's all mounted, balanced, and in hand. I'll also be changing the studs to longer and stronger ones. There may be more options out there. I couldn't find any I liked other than spending $3-4k on new wheels but I need other go fast goodies like a cage first.
    budoboy's Avatar
    budoboy is offline LX Newbie
    Feb 2006
    If you just get 275/40/20s in Nitto 555r drag radials you'll be set for the street. I got good 60' times with them at the track compared to Hoosiers and Mickey Thompsons. They are a little more slippery when its cold out but they last longer than other drag tires. They are also OK in the rain.
    *Winner of New Hemi Challenge Class at Mopars at the Strip (Las Vegas) 2010
    *Winner of 6.1L N/A Class and King of the Hill at Atco Modern Mopar Shootout 2010
    Yeah the 275/40/20 Nitto is a good option, BUT has anyone fitted a Nitto
    305/35/20 DR555r onto a 300. I'd like the widest tire possible...and preferably on a proper 10 to 10.5 rim.
    Doable or not..............anyone?
    slideway's Avatar
    slideway is offline Onward, through the fog
    Jun 2007
    Union co. N.J.
    Quote Originally Posted by bullettrain View Post
    Yeah, PM Ghostface Mag He's running those 305 on 20"x9" rims
    ujokin2's Avatar
    ujokin2 is offline LX Guru
    May 2006
    Suffolk, Virginia
    I ran those too NITTO's 555R in 305's on a 20 X 9 stock rims but had to use a 1/4 inch spacer.
    Ran through 2 sets... before giving up on them for track use... Good street tire IMO
    N/A ET 10.44@128
    Joy ride TT Challenger 9.71@143
    7.5L Aluminum Block 460 N/A 635RWHP\650RWTQ By Lewis Performance Machine
    Quote:
    Originally Posted by Jack SickSRT
    Bring what you got, run it and STFU!
    Ujokin2............Nitto recommends a 10 inch rim as a minimum...was there room for those on a 10 inch rim? Did the centers wear out faster due to the domed shape on a 9 inch rim.
    thanks
    Is the wheelwell in a magnum the same size/shape as a 300?
    NYCSRTATE's Avatar
    NYCSRTATE is offline I Wanna Go FAST!!!!!!!!!
    City That Never Sleeps
    Im running 315/35/20 Vredesteins in the rear with no spacers.
    Curious to see which drag will fit in there after the engine work is done.
    HemiPlus's Avatar
    HemiPlus is offline LX Newbie
    Jun 2008
    Is there any modification of the wheelwell needed for that big a tire (305 or bigger).
    How far does the tire stick out with a 0.25" spacer?
    NYCSRTATE's Avatar
    Quote Originally Posted by HemiPlus View Post
    No wheel well modifications here or spacers, whats the offset on the rim that you will use?
    ujokin2's Avatar
    May 2006
    Suffolk, Virginia
    thanks
    Yes it fit better then expected. Not too much evidence of a domed shape other than yes anytime you tend to put a bigger tire on a smaller rim the the center does tend to wear out faster and also sometimes you do not get the full width of the tire to the ground.
    Did not stickout past the fender and I did not have to modify the wheelwell.
    N/A ET 10.44@128
    HemiPlus's Avatar
    Jun 2008
    Where is the tightest clearance when mounting these wide tires?
    Quote Originally Posted by NYCSRTATE View Post
    Stock 300C SRT8 wheels. Looking into widening the rims 1" if there is room to better fit the tire.
    I looked under there and the front part of the rear wheelwells on the inside looked to be under an inch tolerance.
