Results 1 to 10 of 10
    Hemee's Avatar
    Hemee is offline 2006 SRT8
    winnipeg
    Balljoints? Sway ling bar?
    Hey guys a hand would be nice, i have heard a chlunking for sometime in my suspension, i replaced both outter tierods and it still continued.
    Now a mechanic told me it was a swaylink bar, just out of curiousity, if the chlunking comes from the right side of the car more then the left, is it possible that it may just be a upper or lower balljoint?
    Is that even possible if it is the link bar?
    Any help would be appreciated.
    thanks ken
    -05 300c- "Hemee"
    "Go BIG or go Home"
    -06 SRT8-
    liljoejoe54's Avatar
    liljoejoe54 is offline LX Padiwan
    Sep 2007
    Chicago
    I have heard of the front sway bar links coming loose. I also have a clunk coming from my front suspension and I have had both tensioner struts, all, and all 4 tie-rods replaced and I still get the clunk. I gotta get under and check my sway bar link. If it is loose, it will make noise.
    MY - HEMI's Avatar
    MY - HEMI is offline formerly: chuck-n-michelle
    Mar 2008
    Rochester, NH
    I had a clunk and was much louder/worse on the passenger side. Took it to my dealer and they came up with the sway links being bad. They were replaced and the majority fo the clunk went away and stayed that way for the past 30K miles or so.
    Now I have a little more clunky noise from up front again and this time it is due to excessive play in the outer tie rods. So, that is the next thing to be done in the next few weeks.
    I would definitely have the sway links checked and replaced. It wasn't a large expense (under $175), but have also heard that it is a job that can be done on your own too...
    Hemi Registry #1117
    2006 R/T Police Package
    MattRobertson's Avatar
    Feb 2005
    At the bus stop...
    The factory sway links are about $25 each. Its probably something you can do yourself. I had mine apart in the rear on Sunday to add some washers.
    Hemee's Avatar
    winnipeg
    Thanks for your input makes life good, anyway i picked up both link for exactly $25 each so thankyou Matt and going to do them tommarow!!
    Thanks again everyone.
    -05 300c- "Hemee"
    "Go BIG or go Home"
    -06 SRT8-
    Sep 2007
    Chicago
    Does anybody know the part numbers for the front sway links? I have an '06 Charger R/T if that matters.
    300MAG's Avatar
    300MAG is offline Going No Place Slow
    May 2005
    Woodstock, GA formally from L.I.
    Quote Originally Posted by liljoejoe54 View Post
    LINK, Sway Eliminator
    4895482AB Right
    4895483AB Left
    Sep 2007
    Chicago
    Quote Originally Posted by 300MAG View Post
    4895482AB Right
    4895483AB Left
    Thanks alot bro!
    elcobra44's Avatar
    elcobra44 is offline The times they are a changin...
    Feb 2006
    Batavia, IL
    NYC
    Sway links are DEFINITELY something you can do yourself. It's as easy as changing brakepads. It honestly takes longer to jack up the car and get the wheel off.
    2006 Dodge Charger RT - 6.1L motor, 3.06 rear, Brembos, SRT steering & electronics * KWV2 suspension * Hotchkis sways * BWoody endlinks * SRT fascia & spoiler * Trufiber SRT hood * MSRT wheels * 6000k HID lows/fogs * Aftermarket LED headlamps * MyGIG * 1ST COMPLETE '06-'08 INTERIOR CONVERSION * AFE Stage2 CAI * catless mids * 170 tstat * Predator 93oct tune... & a bunch of other sh!t I cant remember!
