Results 1 to 13 of 13
    Sodes is offline LX Newbie
    Feb 2007
    B-Town, IN
    AWD lug nut gap?
    So I got my Magnum AWD RT last week from a used car dealer. The dealer had 20" wheels on it while it was on the lot. I didn't like the 20s they had so I told them to go ahead and put the OEM wheel back on. I've since noticed what seems to me to be an unusually large gap on the lug nuts. Is this normal/correct or did they use the wrong nuts?
    Sodes
    Mid Night Blue '05 Magnum RT AWD
    Auto Headlights, Blinker Mod, MDS "on" light installation, front tint to match
    Feb 2007
    B-Town, IN
    Now with a picture...
    Sodes
    done's Avatar
    Old Hickory, TN
    No that does not look right. Pull back on the picture so we can see the whole wheel. AWD wheels should look like mine. Follow the link below.
    Invader's Avatar
    Invader is offline I R NUKE
    Apr 2006
    Acworth, GA
    OEM wheels use larger diameter lug nuts (outside diameter). The lug is 14x1.25. The larger OEM ones have a larger contact patch in the cone area. My OEM ones would not fit on my aftermarket wheels.
    boggart's Avatar
    Pittsburg, KS
    sure doesn't look good.
    RandomAccess's Avatar
    Monroe,NY
    Definitely not right.
    12.571 @ 106.71
    lower8 is offline The weekend heals us!!
    Dec 2006
    N.W. Phoenix
    is there any play in the wheels?
    have you grabbed them and pushed back and forth on the wheels?
    "DRIVE IT LIKE YOU STOLE IT!"
    Jim Edwards/meister
    -mooreauto.com
    -AZLX club
    LowGo's Avatar
    LowGo is offline Alter ego of MyMaggieMae...
    May 2005
    Gresham OR
    Something definitely doesn't look right. It's hard to tell from the picture, but are there spacers between the nuts and the wheel? If so, that's not right.
    Inferno Red '05 Magnum RT AWD - Who says the AWD sits too high?!
    German influenced garage queen .................... German engineered daily driver
    Monroe,NY
    I wonder if they used lugs meant for the RAM. Honestly those lugs are crap anyway. My dealer keeps breaking them when they rotate the tires. Maybe best to just go get a set of gorilla's or something.
    12.571 @ 106.71
    Feb 2007
    B-Town, IN
    There is no play in the wheels, I now know they aren't correct, but the Dodge dealer wants $85 for a set of replacement lugs. Invader, you want to get rid of your OEM lugs that you have?
    Sodes
    Monroe,NY
    If you just bought it the dealer should give you the correct lugs... If not.. save yourself $60 and buy this set of gorillas for $26
    http://estore.websitepros.com/802805/Detail.bok?no=1007
    They are solid instead of that hollow stock crap.
    12.571 @ 106.71
    boggart's Avatar
    Pittsburg, KS
    Holy crap, don't pay them that much for crappy lugs. Get the ones RA linked to.
    Feb 2007
    B-Town, IN
    Quote Originally Posted by RandomAccess View Post
    Thanks for the help, order these this morning. Now I'm on to changing the exhaust, but that's a different thread.
    Sodes
