Results 1 to 15 of 30
    t walgamuth is offline t walgamuth
    lafayette Indiana
    AWD caster available?
    I am not happy with the way my car tracks on the highway. It feels like it needs a lot more caster. Does anybody know how much is stock and how much caster is available with aggressive adjustment. I would like to get six or seven degrees like the usual amount in its cousin the mercedes.
    Tom W
    fnkychkn's Avatar
    greasy cardboard box
    specs in TSB 02-002-05.
    lafayette Indiana
    Thanks, mr. Funkychicken.
    I read through it all and I am not sure what it means. It recommends only 4 to 5 degrees caster for the awd, and 9 to 10 in the rwd. I still do not know if more caster is available in the awd. Can you translate for me? And is the recommendation offering more or less caster than my car has from the factory?
    Tom W
    fnkychkn's Avatar
    AWD front propshaft cannot handle 9-10* of caster. differential pinion shaft angle would be too great and a vibration would result.
    EDIT: kindly disregard this post. the information contained herein is completely inaccurate. as a matter of fact, this member should be publicly ridiculed for spreading such falsehoods.
    lafayette Indiana
    so you are saying that the only way to change the caster is to tilt the entire subframe assembly including the diff?
    seems kindof silly. do you know why they would have done it that way?
    Do you know what the caster is set at from the factory? and what is the max I could reasonably expect to achieve if I had it maximized?
    Thanks for the responses. YOu sound very knowledgeable.
    Tom W
    Turf's Avatar
    Turf is offline '05 Dodge Magnum SXT AWD
    Jan 2006
    Michigan
    im interested in knowing what your complaint on the way the car tracks on the highway is. my car seems nervous and twitchy, and ive wondered if caster adjustment would help. the dealer has checked the alignment and says its within specs, but i didnt think to ask him what the actual numbers were.
    im not looking for sportscar suspension tuning, i want it to feel stable. as it is, 1mm wheel adjustment either way and im going across the lane. what would be a recommended caster setting for a more stable track? plus or minus side of the range?
    LowGo's Avatar
    LowGo is offline Alter ego of MyMaggieMae...
    May 2005
    Gresham OR
    Quote Originally Posted by Turf View Post
    I'm a little confused by your statement. It sounds like what you want is a less responsive system. I don't think a caster adjustment would affect that in any way, unless you're having other steering issue. These cars do have a very unforgiving steering system. I find it to be very stable and preditable and personally like the way it functions. But, if you get distracted and move the steering wheel the least little bit, you're going to be moving in that direction!
    Inferno Red '05 Magnum RT AWD - Who says the AWD sits too high?!
    German influenced garage queen .................... German engineered daily driver
    fnkychkn's Avatar
    Quote Originally Posted by t walgamuth View Post
    Tom W
    sorry Tom. must have worked on nothing but Jeeps that day. guess i had solid axle on my mind.
    Turf's Avatar
    Jan 2006
    Michigan
    Quote Originally Posted by LowGo View Post
    yes, im asking for a less responsive handling at highway speeds . i find it not so stable though, hit a bump on one wheel and the wheel jerks in your hand and if you dont have a good hold, it'll pull you that way. variable power assist would be great, it feels like it is over-boosted, great in a parking lot, not so great at speed.
    sorry to hijack!
    lafayette Indiana
    no hijack.
    my complaint is the same. i have had as my daily drivers nothing but old mercedes for about 15 years.
    i drove a 300 rwd a thousand miles as a rental a couple of years ago and found the handling very mercedes like. so i bought this '05 awd maggie thinking it would handle pretty much like the rwd car and found after driving it a bit that the steering requires much too much attention on the highway. as you say, the slightest movement of the wheel has the car heading off where you dont want it.
    more caster is what a merecedes has, what a rwd maggie has and also what a race car has.
    so I would love to figure a way to get more caster in my magnum.
    i used to do this with my old suburbans. it made them a lot more forgiving on the highway at the very acceptable trade off of less sensitive steering.
    So my question is how much caster is built in, how much adjustment is available?
    I am hoping to tap some expertise of a knowledgable alignment guy who has familiarity with the awd magnum.
    Thanks for the responses so far.
    Tom W
    LowGo's Avatar
    May 2005
    Gresham OR
    Since I'm no expert on suspensions, I did some reading on the subject to get a better understanding. I didn't realize before that there was such a big difference between the AWD and RWD. While I don't personally have a problem with the AWD, I haven't driven a RWD enough to really know the difference in handling.
    From what I've read, it doesn't look like there's a whole lot of stock adjustment capability for the caster. I wonder what the reason was for not making it the same as the RWD. Hopefully someone with more knowledge will chime in with some info.
    lafayette Indiana
    i think maybe the suspension for the awd is from the m class mercedes... hence the wider hub situation dictating the different offset wheels and the huge brakes. necessary for the awesome power of the hemi.
    i don't have a good idea as to why they build them with such a small amount of caster.
    Tom W
    fnkychkn's Avatar
    checked with our alignment tech today. he said the only way to adjust caster is by moving the cradle, which will also change the camber.
    lafayette Indiana
    So if i have the cradle moved can i increase my caster, and then have the camber readjusted so that the car tracks better and is more relaxed on the highway?
    Tom W
    Turf's Avatar
    Jan 2006
    Michigan
    and i wonder if LowGo maybe has the cradle on the high end of the adjustment, and if we who feel its too sensitive are at the low end?
