deleted
deleted
Mickey Thompson ET Street...275/40/17 totally kicks ass...aprox 12in wide footprint. I mounted them on some cheap cragar steelies.
I went from having to smoke the hell out of my BFG 245/40/18 DR's and pedal them out of the hole..... to just cleaning off the ET Streets with a couple dry hops and then being able to nail the throttle out of the hole.
My last 10 60's have been between 1.75 - 1.79
Be warned, you will need 6200 shift points with these tires to ensure you stay in 3rd gear.
Stupid Nasty.... 9.59 @ 148
PWR heads+FRI intake / HHP-BES Forged 6.4 / HHP Stage 4 cam / KOOKS LT / Pro Torque 2800 / Southern Hot Rod NAG1 HTCr - V-7 YSI @ 19 PSI, 200 shot N20.
It has been confirmed the SRTs can run the 17" rim on the rear hasn't it...a Cragar if I remember....
Can anyone confirm...
I heard trhe M&H ones were pretty good... PowerWagon knows about all this.
I checked summit racing and did not find the crager steelies you were speaking of. You have a location to purchase these from?
I have a feeling I'm going to need a set of these soon...
BFNY PERFORMANCE
RIP My Friend
Summit didn't have them huh?These are the steel Cragers from Summit......It's a 4 1/2 bolt circle....maybe thats why you didn't see them.
http://store.summitracing.com/partdetail.asp?autofilter=1∂=CRR%2D3988912&N=700+4 294923107+4294923105+400292+4294793320+4294795022+ 4294755963+4294755966+4294911383+115&autoview=sku
BFNY PERFORMANCE
RIP My Friend
So Erik if I order the ones on the page you just posted those will fit on my SRT-8?? Correct?
I am 99% sure that is the same size as the ones we stuck on my car.PM Powerwagon to verify.
BFNY PERFORMANCE
RIP My Friend
Part #ItemPriceQtyPriceCRR-3988912 Wheel, Soft 8, Steel, Chrome, 17 in. x 9 in., 5 x 4.5 in. Bolt Circle, 5 in. Backspace,
Each $94.95
Total:$189.90
Handling Charge:$10.95
Total Order:$200.85
http://www.carcraft.com/techarticles/performance_tires/
A Sticky Situation
Follow Along As We Debunk The Myths, Bring You The Facts, And Give You The Skinny On Straight-Line–Oriented Performance Tires
