Results 1 to 6 of 6
    deleted
    MAGFX is offline Nevermind my mind!
    Dec 2005
    Arizona
    I am pretty sure that it is fixed and the only camber adjustment accessories for our cars are from Eibach or SPC (Specialty Products Co.). I think they come in ±.75° and ±1.5°.
    I smile because i have no idea whats going on.
    My friends call me JONN (usually).
    PHANTZM's Avatar
    PHANTZM is offline Formerly known as Suipsycho
    Arizona
    402Motoring has em. The rear for $58.99 plus 9.99 shipping.The fronts are more expensive and are $248.95 plus $12.99 shipping. They are priced better than all the others I have looked at. But your choice in the end.
    I'll likely be getting a set soon as I am running with the Eibach Sportlines. Figure its a small price to pay until I can afford to have it bagged.
    ~Gary
    lowriderman3's Avatar
    lowriderman3 is online now Rut Ro!
    Low Down Dirty South!
    SPC is what I used in the rear. SPC also makes them for the front as mentioned above.
    http://search.ebay.com/search/search...&fsop=1&fsoo=1
    Also there is a bushing press tool that is used to get them off and on. My mechanics shop had to order it, but yours might have it.
    http://www.iapdirect.com/pictures/66010.pdf
    Kim Hufty is offline LX Padiwan
    Southeast Mi
    The factory has 3 different length camber links that they use for build tolerances. They have a nominal , +1mm and - 1mm. Each mm gives you about .8 or .9degree adjustment which is a fair amount.
    If you look on the side of the link there is a part# number peened into the link. The dealer should be able to tell you which length you have to see if you can just buy another link for adjustment.
    If I remember I will get the numbers next week and post them up.
    SHAKER check, Heads check , Cam check , tuner check, CAI check, LT 's check, Borla check, ext, ext, ext
    12.8358 @ 108.46
    MAGNUM8R's Avatar
    MAGNUM8R is offline Yes I am a pirate, 200 years too late
    So. California
    Never went there, with the KW drop, my front is more tweeked than the rears, as as I have about 3/4" rake going on...
    No weird tire wear, but it is dang "darty" on straight line freeway driving.
    Corners like go cart tho, I like it!!!
    Looks like this: / \ but works fine IMHO.
    An over 40 victim of fate.
    '8R'05 Magnum RT Midnight Blue Pearl
    KW V 2 , Hotchkiss Sway Bars, CF Airhammer intake,T Rex Billet Grille, Body color Airtab Vortex Generators, Chromed stock 18's BFG KDW 255/55/18 Tires,Avon splash guards, Gibson Performance Stainless SteelHeaders, GibsonCat back, SC 91 Performance tune.
    Hi Flo Cats
