Results 1 to 7 of 7
    89grand's Avatar
    89grand is offline LX Guru
    Phoenix, AZ
    Any benefit to BT 3mm spacers over generic spacers?
    I have the generic universal 3mm spacers and was wondering if there is a good reason to replace them with the BT spacers.
    I'm sure the BT's are stronger, but other than that, what do they offer?
    I have a little shimmy on the freeway and am thinking it's my current spacers.
    2000 Jeep Wrangler
    1966 Dodge Monaco 500
    MOL SRT-8's Avatar
    MOL SRT-8 is online now SHOW & PERFORMANCE
    Dec 2006
    SAN DIEGO, CA
    1 word quality
    WWW.SHOWANDPERFORMANCE.COM
    SoCalLX
    Congratuation Del Worsham
    2011 Top Fuel Champion
    Mighty Noid's Avatar
    Mighty Noid is offline time to paint the car soon!!!
    Aug 2005
    SoCal
    Plus they are hub centric and most likely yours in not... so yes it will most likely take away that highway shimmy... I would get them...
    Thank you Bigal470
    Redfox0099's Avatar
    North Charleston, SC
    You will be putting money into a good company that supplies quality parts
    Reason enough for me.
    Posted via LXFMobile
    HerDaytona's Avatar
    HerDaytona is offline Wifeys Grape Ape
    Dec 2007
    Where it's Warmer
    When my wife, Plum Krazy mounted up her newly acquired wheels from Trojans Challenger, the 3mm spacers were used. I cleaned up the mess around the lug studs created from factory wheels and steel brake rotors. That way the new spacers were flush on the stock rotors. Now this is only at 15k miles too.
    No "slop" movement on the brake rotor from the 3mm BT spacers
    No shimmy or vibrations either at 80 plus mph. So we all good here!!!
    Super T's Avatar
    Aurora, IL
    Hubcentric!
    89grand's Avatar
    Phoenix, AZ
    OK, I'm going to buy them, but not just because they are good or the company is, but hopefully because I'll benefit over what I have now.
    I know they're hubcentric, but does that really help? I mean it's just a spacer, it doesn't do anything to make the wheel centered. I'm not saying that doesn't, just curious. I could see that they could be more true, an exact 3mm across vs maybe the cheapos aren't and I can see that causing a problem, but I don't fully understand how the spacer being hubcentric would make a difference for shimmy in the steering wheel.
    Can someone explain this?
    2000 Jeep Wrangler
