Results 1 to 5 of 5
    jasonr_01's Avatar
    jasonr_01 is offline I've got wood!
    Iowa
    Any 22" wheel issue's need addressing!!!
    I recently have purchased a set of American Racing Cryptic's with a +18 offset and 5x115 bolt pattern, i'm going to be running 265/35/22 nitto 420's. I'm wanting to know is there any issue's I need to be aware of, as of Rubbing? The suspension bolt, located above the tire? Anything that you fellow 22" wheel owners have noticed to be an issue, with this type of setup. any info. would be great.
    The mod List is getting to the point that its just to long to post. So if you wanna know whats in it, just ask?
    lowriderman3's Avatar
    lowriderman3 is offline Rut Ro!
    Low Down Dirty South!
    No problems here. I am running a 255/30/22.
    risky's Avatar
    risky is offline LX Guru
    nj
    none
    I panicked when I saw how close the suspension bolt was, but no rubbing issues--foose nitrous 22's with 265/35/22 tires
    jasonr_01's Avatar
    Iowa
    06SilverSteel's Avatar
    Jun 2006
    Houston, TX
    Only issues I have are the rears rub just a little on big bumps....no problems with the front.....22X10 in back and 22X9 in front....295/30 and 265/35's.
    http://i117.photobucket.com/albums/o...erStuff021.jpg
