Results 1 to 5 of 5
    Jon3sgte is offline LX Padiwan
    Feb 2011
    Tucson
    Another "will it fit question"
    I am currently running 245/45 on my 20X9 (+18 ET) and its time for tires. I plan to run 275/40 which I know will fit the wheels. The question is this: will I need to roll fenders once I put in 2" lowering springs? Rolling isn't an issue, I'm just curious.
    Supleme is offline LX Padiwan
    Dec 2009
    You should be ok. You may have to roll the rears.
    Feb 2011
    Tucson
    ^cool, thanks!^
    drift_sucky's Avatar
    drift_sucky is offline LX_Slider
    Rochester, NY
    I'm pretty sure you won't have to roll the fenders on that. While it's wider, there's a shorter sidewall. The "hieght" will typically give you more issue than the width up until 295+. If your springs settle more than that 2inches or your shocks or bad, you may have to roll fenders but based on the specs, you'll be fine.
    Just things of note: what I said holds true on a standard, non-aggressive setup. ONce you start getting into slamming and camber and flush, things change a bit.
    Quote Originally Posted by STREET LIFE R/T View Post
    The size of his wheels and stance not being right makes him a drug dealer..WTF.
    Feb 2011
    Tucson
    I guess this didnt help me much as I found a steal on a set of 245/45 and 255/45's. Eventually I'll go wider but I couldnt pass this up. Thanks for all the replies!!
