Results 1 to 5 of 5
    CT-MSRT's Avatar
    CT-MSRT is offline LX Guru
    CT
    Alternate use for rims
    I purchased a winter tire package for my 2007 SRT Magnum this winter and have loved the way it worked out. It was an investment so i want to make sure i get some good years out of it. I am thinking about picking up another LX this year for work and random driving. What other LX's will these rims fit on?
    http://www.tirerack.com/wheels/Wheel...XL&qty_front=4
    18X8.5
    Offset: 15mm
    Backspacing: 5.35"
    Bolt Pattern: 5-115
    Rec. Tire Size: 235/60-18
    Weight: 26.0lbs.
    I was thinking about a 300 limited. I doubt these would fit on an AWD but it would be awesome if it was possible. A RWD model would be fine as well since they still handle extremely well in the bad stuff.
    Current mods: Hi-Flows, 180. POC, PS Cooler, Trans Cooler, SS Brake Lines, Ti Backing Plates.
    Pedders Track II Extreme, Wavetrac, MOPAR 6.1 TCM, Mopar trailer hitch and harness.
    CT-MSRT's Avatar
    CT
    Well, after some research i found that Matt had picked up a set of these for his record setting Leguna Seca runs. Looks like i'll be buying slicks!! Thanks Matt
    gsjoe's Avatar
    gsjoe is offline You talk'n ta me?
    Feb 2005
    st louis area
    What is the wheel width on the oem 20s for the SRT8?
    MSRT8
    Zoomers exaust, CFAH intake, Inertia ported with spartan max cam, predator w tune
    CSRT4
    Zoomers exaust, mopar s1, driver mod box, scan gauge
    CT-MSRT's Avatar
    CT
    i wanna say they are 20x9
    MOL SRT-8's Avatar
    MOL SRT-8 is online now SHOW & PERFORMANCE
    Dec 2006
    SAN DIEGO, CA
    Quote Originally Posted by CT-MSRT View Post
    correct
    WWW.SHOWANDPERFORMANCE.COM
    SoCalLX
    Congratuation Del Worsham
    2011 Top Fuel Champion
