Results 1 to 2 of 2
    NVRDUN's Avatar
    NVRDUN is offline LX Guru
    Las Vegas
    Alignment problems after drop
    I installed the Eibach pro system which is a set of Pro springs and Eibach dampers. Well I took the car in for an alignment and they told me everything was in spec except for the right rear tire, it had too much negative camber.
    So I decided to take it to another place. Well the second place says all four tires have negative camber, three tires have toe in and both front tires are out of caster?
    We are talking a difference of three days between the tow alignment shops. I didnt even drive between the two alignments.
    So now what the heck do I do? The numbers from both places dont even match. I am very frustrated and Im not really sure what to do?
    moonstreaker is offline LX Guru
    NJ
    I say try a third shop. The numbers should be close enough to one of the other shops' to know which of the first two screwed up.
