Results 1 to 11 of 11
    MonkeyBoy's Avatar
    MonkeyBoy is offline Member of the Butter Boy Club!
    Nov 2007
    Everett, Wa
    Alignment help needed...
    I recently did an install of an SRT-8 suspension off of a 300c srt8 onto my charger minus all of the isolators. Also done in the install was a set of Hotchkis sways. I love the new look and drop, it handles beautifully....
    My issue is this, I went to get it aligned as would I after any suspension mod and they are saying that I need to spend a little over a thousand dollars on parts to make my suspension adjustable at all as far as camber and caster goes. They are saying that I need to replace the front control arms and put a bushing replacement kit in the rear.
    Has anyone else ran into this problem? What are my alternatives.... A thousand bucks just seems too steep for a friggin' alignment.....
    If any of y'all have any input that would be spectacular!
    Thanks in advance!
    Tony
    Yeah Whatever
    PNWLX.COM
    xxxmsrt8xxx's Avatar
    xxxmsrt8xxx is offline Next Level Motorsports
    Dec 2007
    MA
    When they do the alignment have them set the specs to a charger srt8. They should be able to align it.
    07 MSRT8, Techco blower, custom exhuast by me. 514whp 490tq
    03 Lancer Evolution, in the procees to see 700whp
    03 Ram 3500, lifted, stacked chips
    99 Dakota R/T, full out drag truck, the 740hp 360 is out and the engine bay is waiting for its 440
    myspace.com/xxxevoviiixxx
    MonkeyBoy's Avatar
    Nov 2007
    Everett, Wa
    Would that allow them to adjust the camber or caster at all?
    Yeah Whatever
    PNWLX.COM
    Dec 2007
    MA
    The camber and caster specs will be diff for the SRT. If they set it up for the reg charger the specs will be all off. So when it programed for a SRT the camber and caster should read fine. I own a shop in MA and we do alignments all day, bring the car to MA i will align it for ya.
    MonkeyBoy's Avatar
    Nov 2007
    Everett, Wa
    Ok, Thank you, I just called Les Schwab and told them that. He is going to check the computer to see if the specs will line up and call me back..... Oh and, if you mean Masechusetts, I'll see ya in 6 days then! Lol
    Yeah Whatever
    PNWLX.COM
    MonkeyBoy's Avatar
    Nov 2007
    Everett, Wa
    They just called and said that it did change a little, but that I will still need to replace some parts....
    AAAHHH Are there any cheaper kist available?
    Yeah Whatever
    PNWLX.COM
    Dec 2007
    MA
    Yah i do, good road trip. Good luck with the alignment
    fast fred's Avatar
    fast fred is offline LX Padiwan
    Jan 2008
    antioch calif.
    i have something close going on ,i had the eibach pro-street-s coilovers and hotchkis sways and i do like the look and handling alot but the shop is saying that i need 1,200.00 in parts and around 6 to 7 hundred bucks in labor to get my lowered plum crazy into alignment.. its crazy.....i'n going to raise my up a little and save some $$$$.....
    i'm fred & yea i'm a MOPAR nut-1979 dodge power wagon-2000 plymouth prowler-1988 FERRAI 328 GTS
    smoove7410's Avatar
    smoove7410 is online now 2.0 x 3.0 x 5.0 ÷ 10.0 + 1.0 = 2.0²
    Apr 2004
    Los Angeles
    ^^All you need are rear camber bushings. Mine is lower than yours and I just have rear camber bushings. I aligned it yesterday expecting the front to be way off, and to my surprise, they said everything is good. Don't waste your money on front a arms.
    MonkeyBoy's Avatar
    Nov 2007
    Everett, Wa
    I gotchya, but the thing is is the fronts are requiring a 1 degree outward camber... The bushings are cheap enough to where I will buy them but I still worry about the front......
    Yeah Whatever
    PNWLX.COM
    SJCHARGER is offline B.A.M.M
    Jan 2008
    SaN jOsE caLi
    I got a set of the front spc kit brand new in box. Its the adjustable upper control arms. Im asking 270 shipped. heres the link
    http://lxforums.com/board/showthread.php?t=164501
