Here is a little write-up I did on handling upgrades for my LX and thought it was good information to share here.
GRABBING THE CORNERS
HOLD ON TIGHT! WE’VE BUILT THIS MODERN MUSCLE CAR TO HANDLE ANYTHING WE THROW AT IT!
BY MATT SPROUSE
Performance: a word that is practically extinct from Detroit’s current production models. With the exception of the Corvette and Viper super cars and the more moderately priced Mustang and Challenger, there seems little left for the traditional muscle car enthusiast. One overlooked jewel might just be Chrysler’s rear-wheel drive LX-platform, which contains 300-plus horsepower, fully independent suspension, and aggressive looks that rival any Euro sport touring sedan.
The LX-platform encompasses the Dodge Charger, the recently retired Magnum, and the Chrysler 300. These models share the same
suspension components, chassis design and best of all, they’re all available with the optional 5.7-liter Hemi V-8, giving them more than enough power to rival most GM or blue oval rides. Additionally, Hemi-powered LX cars have become far more affordable, and the automotive aftermarket has continued to support them with performance and appearance upgrades.
We decided to really test the limits of the LX-platform with our 300C project car. Our direction seemed set from the beginning: the 300C had all the power we needed (at least for now), but the suspension was really set up for a softer touring car feel. Our goal was to refine the suspension and handling characteristics enough to make it feel at home on city streets or at the road course on the weekend. With all the right components intact—struts up front and a fully independent rear suspension—we were convinced that with a few changes we could have our 300C handling on par with some of the best.
No aspect of the 300C’s suspension will go un-scrutinized as we work to transform the car’s sluggish feel in the corners into a corner carving g-machine. Follow along as we select our components and build the new American “muscle car.” You might just change your mind about these sedans in the process.
AIR RIDE TECHNOLOGIES-LX KIT
Because we’re striving for improved handling on the track, a low stance and a contour-hugging suspension is necessary, but keeping it streetable is exactly why we went in the direction of air pressure versus coils. There are many companies making air suspension systems for the LX-platform, but we needed the best for performance handling, which made the choice simple. We selected Air Ride Technologies components for our project because they aren’t just about laying the frame on the ground; their components are built with performance in mind. While attending a track event featuring exclusively Air Ride Technologies-equipped vehicles, one extreme trip around the track with NASCAR roadrace driver, Boris Said, helped drive the point home of the performance benefits of quality air-suspension systems.
Air Ride Technologies’ new kit for the LX-platform provides excellent tunability, which allowed us to easily tailor our 300C for the street or the track. Double-adjustable ShockWave front struts allow tuning of rebound, compression, and ride height and replaced the soft factory struts. The CoolRide rear system replaced the springs with high quality air bags and double-adjustable shocks, making this kit perfect for a daily driven car that can be dialed up to kill for the track.
The brains behind the suspension is the LevelPro system and the new AirPod. Gone are the days of constantly monitoring air pressure to level the car properly. Plumbing older systems was a chore as well, with all the compressors, solenoids, computer, tank, and wiring being independent units. The recently released AirPod makes short work of setting up a new system; everything is consolidated into one compact unit, minimizing noise and space needed in our trunk.
With all the guesswork taken out, the Air Ride Technologies LX kit was a breeze to install. We won’t apologize for the lack of step-by-step photos in the installation; it really is that easy to install.
1. We began by safely and properly supporting the car on a lift. After bracing the lower control arm with a jack, we unbolted the control arms to allow the lower A-arm to swing freely. We then lowered the jack to remove the stock spring, and also removed the three shock bolts.
2. Utilizing existing factory holes, the CoolRide rear setup was bolted to the lower A-arm. Using a USS 7?16-inch tap we cut threads into the hole on the outside, while the inside hole used a nut and bolt.
3. We attached the air bag lower plate to the A-arm using a 7?16-inch bolt and lock washer. For clearance, a 3?8-inch button head bolt and nut secured the inside.
4. Before we attached the upper mount, it was necessary to connect the air lines even though we had not routed them to the AirPod. The DOT-approved plastic lines simply slid into the fitting and were secure when pulled.
5. To attach the upper air bag bracket, we clamped it in place, marked the location of the holes for the mounting plate on the upper spring perch, and then drilled the bolt holes with the plate removed.
6. The double-adjustable shock is a factory replacement part. We attached it to the lower A-arm and bolted it to the top of the shock tower.
7. Installing the new front ShockWave struts was pretty straight-forward. After removing the spindle from the upper A-arm, we removed the stock strut and bolted the new ShockWave to the lower A-arm. It’s a good idea to connect the air lines at this time as well.
8. While the factory struts used studs to secure the top, the new ShockWave assemblies use three bolts instead.
9. After attaching the air lines to the struts and air bags, we routed them through the fender wells and beneath the floor pans, keeping them clear of contact from exhaust, sharp edges, and moving parts.
10. After checking suspension and wheel/tire clearance, we located a good spot in the fender well to mount the Level-
Pro sensor. We modified the sensor arm for shock and anti-sway bar clearance.
11. Welding a tab to the lower A-arm provided an attachment point for the LevelPro sensor.
12. The front sensor arms were attached to the lower tab on the anti-sway bar mounting bolt.
13. We routed the air lines and sensor wiring to the trunk. Rubber grommets were used in all drilled holes. As a precaution, anywhere lines or wires came in contact with an edge, we covered them with protective sheathing to prevent damage.
14. The AirPod fit perfectly between the wheel wells in the trunk, mounted to the floor. Connections for the air lines and wiring were clearly marked, making installation a snap.
