Results 1 to 2 of 2
    Bradyb's Avatar
    Bradyb is offline '07 R/T Charger/08 Solstice GXP
    SLC UT
    Air Lift 1000 Bags, Require Load Leveling?
    Hello Folks,
    Has anyone used load leveling bags on their cars? Do they work well, do you know which kit fits our cars?
    I want to set up my R/T Charger for towing. I don't have the load leveling shocks. Would I be okay with just installing the Air Lift 1000 Bags with the base R/T rear shocks? Aren't the load leveling shocks just adaptive with load, it's not like they use a compressor or have an electronic hook up, right? I already have the onboard compressor for my big R/C airplane retract systems that I could use that with the bags. The Bag kit is only like $100 and is good for an extra 1000 pounds.
    The Charger is our family car I was hoping to get some more utility out of it with out changing the grandma floater ride.
    Should I grab the oil cooler, radiator, and tranny cooler off a wrecked highway patrol Charger?
    Jeremy@AirLift's Avatar
    Jeremy@AirLift is offline Supporting Vendor
    Quote Originally Posted by Bradyb View Post
    Hello Folks,
    There is not a kit p/n number available yet, but we are working on one. If you can get me the measurements of the inside diameter and height of the coil spring at your normal ride height I can find a bag that will fit inside of the spring. These work perfect for keeping the rearend level. If you have any questions, let me know jhart@airliftcompany.com
