I bought my car used about 7 months ago and loved it and didn't notice anything wrong. Shortly after I started noticing a mild clunk sound in my front end and this is where my whole life came crashing down on me :( I started researching this issue ( google, yahoo and all the forums) I found A LOT of people with similar problem and was glad I wasn't alone. I started fixing things that people fixed the problem that weren't the most expensive. I fixed sway bar bushing (cheap) and that didn't fix. I then moved on to the sway bar links ( cheap) and that didn't fix. I then moved on to my hub and bearing assembly because it had some play and thought that was it for sure ( semi expensive) and that didn't fix it and my old one was it great shape. I then decided to upgrade my sways to Bwoodys (expensive) and that didn't fix. I then moved on to my tension struts because it seemed like everyone solved there problem replacing these and clunk went away but mine didn't!! BTW: my ball joints were shot ( semi expensive). While doing my tension struts I noticed my tie rods were shot and also replaced ( semi expensive)and didn't fix the problem. At this point I was looking for a cliff to drive my car off of or a charity to donate the car to. ( didn't because felt bad someone would kill themselves over this clunk)
While getting my alignment done the best thing happened to me. I met someone who actually knew what they were talking about and wasnt looking at just taking my $$. He told me I had bad strut mounts and needed a camber kit to fix my alignment. I ordered the strut mounts and the camber kit (upper control arms expensive). While installing my upper control arms and replacing my strut mounts I isolated the creaking sound I was also having and it was from my aftermarket sway bar links. ( I removed and sound was gone and replaced and sound came back).
I replaced the strut mounts (semi expensive) and fixed the clunk and some of my vibration. I also fixed my camber and alignment with the upper control arms and notice the ball joint on the stock upper control arm was way shot! ( expensive) and fixed the problem completely!!!
I have ZERO CLUNK!!!! That's right ZERO CLUNK!!![]()
I just threw a block party for resolving this issue and I'm so happy to have a car to drive that doesnt sound like a cash for clunkers car. (miss my lexus)
I do have 2 problems remaining and are small.
1. still have a creaking sound but its from all new front end parts and Bwoody sways. not a biggie.(fixed got rid of bwoody sways)
2. My new upper control arms are WAY beefier and need to cut a little off the wheel well because it hits when going over bumps. ( will fix tomorrow and not a biggie) (fixed cut out some of the wheel well)
I have taken out almost every part in the front end and can help with almost any sound you are having if you need some. I had a few different clunks and fixed them ALL!!!
Parts repaired:
Sway bar bushings -OEM
Sway bar links-OEM & then upgraded to Bwoody. Removed Bwoody and replaced with Moog. Will be buying RE links soon.
Hub and bearing -aftermarket (forgot brand)
Outer tie rods- aftermarket ( Moog) great
Tension struts- aftermarket ( Mevotech) great
Adjustable upper control arms ( alignment kit) - aftermarket ( Eibach) INCREDIBLE!!!
Strut mounts- OEM
My word of advice from all this is that OEM balljoints are the worse ever!! Dont replace with OEM and buy aftermarket. The upper control arm ball joint and tension strut ball joint were in terrible shape and will cause a very bad clunk!
Please PM if you need any help or post comment and I will be more then happy to answer for the rest.
1Likes
I just wanted to ask you some questions. Thought i would PM but maybe this helps other people.
