After 275/35/20 michelins Car is sitting to high.
will my car ever come down. what the hell is going on. cannot understand why it is sitting to high. i had them installed this past friday. do i need to wait a while for it to settle or should it be immediate.
The overall tire diameter of a 275/35-20 is most likely shorter than the tire you removed. A 275/40-20 is the roughly same diameter as the factory tires. Your 20" Michelin (27.6" o.d.) is over an inch shorter than the factory Goodyear 245/45-20 (28.7" o.d.). You're probably looks like it's sitting about 1/2" higher, right?
- You may not post replies
- You may not edit your posts
Forum Rules
