Page 1 of 3 123 LastLast
Results 1 to 15 of 33
    1FST4DR's Avatar
    1FST4DR is online now I have Gas.. And lots of it ;^P
    Ft Laud.....
    80mph shake after rotation????
    I rotated my tires side to side.Now I get a shake or shimmy if you will @ 80mph.Pretty bad too..Any ideas why??
    SRT8U's Avatar
    SRT8U is online now www.speedlogix.net
    Jun 2006
    South Florida
    Hmm...di you double check your lug not torque? If not my only other thought would be uneven wear and now that they are rotated it is causing the shimmy feeling.
    Kris | Mopar Specialist | Speedlogix, Inc.
    2006 Charger SRT8 Vortech Supercharged by SpeedLogix
    *** We Price Match - click here to see how it works! ***
    Speedlogix, formerly named BMC Performance ... same people, new name!
    Visit us online at Speedlogix.net or call 888-SPD-LOGX to talk to one of our Mopar experts!
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by SRT8U View Post
    Funny thing is my car was rock solid at all speeds...If there was uneven tire wear wouldnt you think I would notice it before the switch???Lug nut torque????????I used an impact gun??there definitly not loose...
    Sonny is offline LX Newbie
    Jan 2006
    SW PA
    rotation
    Quote Originally Posted by 1FAST4DR View Post
    When side to side, did you mean dismounting tire from wheel and remounting on other side wheel. If not, removing the wheel/tire from one side and mounting on the other will cause tire to rotate in opposit direction. On some steel belted tires it is recomended not to change rotation direction.
    SRT8U's Avatar
    Jun 2006
    South Florida
    I guess I am going to start calling you Ricky Bobby...Shake and Bake!!
    Invader's Avatar
    Invader is offline I R NUKE
    Apr 2006
    Acworth, GA
    I hope you seriously didnt use an impact to tighten your lugs...
    If they got overtightened it can warp the rotor, hub, cause a wobble....
    torque spec is 110 Ft/Lbs. Impacts can go up to 600 or more
    Speedlogix's Avatar
    Speedlogix is offline ** Modern Mopar Specialists **
    Jan 2007
    Florida
    Impact wrench .... bad Ricky Bobby. Just take them off and get some Foose wheels (you know, like your favorite Mustang) and be done with it!
    Lisa | Owner | Speedlogix ... formerly named BMC Performance
    2011 Green w/ Envy 392 Challenger
    We Support Challenger Club of America // CCOA Forums
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by Invader View Post
    I understand what your saying,but it does have an adjustment and I didnt sit there for a 1/2 hour per lug nut with the impact on it waiting to snap wheel studs...lol...I dont understand why its so important on these cars regarding torque specs to tightin a wheel..Never had to worry about that on the 50 or so vehicles I have owned over the years..However I will do what you suggest and check the torque..Thanks for the info...
    nhdave's Avatar
    nhdave is offline This space for rent.
    New Hampshire
    06 Inferno Red Magnum SRT8
    Pretty stuff: Blinker mod, Silverstars, Auto Headlight, ERF Backups, 22Elite console w/Jina's stitching
    Go-fast stuff:
    Arrington 426 w/607 cam and FRI Heads by BFNY Performance, Tuned by HemiTuner, Kooks, Protorque 2800, Airhammer, 180 t-stat, Cool-It, B&B Catback
    11.973@112.45 N/A
    11.42@117 - 1.579 60'
    juiced
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by Sonny View Post
    I have heard that before,but there are other members that have done this with out issues..Tires only have 8900 miles on them when switched..FYI I switched the tire and wheel not just the tire..Thanks for the info...
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by nhdave View Post
    Thanks for your input...I will try that too..
    are you supposed to change the rotational direction on those tires? i don't think it is recommended.
    fnkychkn's Avatar
    greasy cardboard box
    crack all wheel nuts loose. retorque in three steps 60/85/110 using a diagonal pattern.
    06SilverSteel's Avatar
    Jun 2006
    Houston, TX
    I'm failing to see the problem here....80 is just a brief moment before you get to 90!!
    TrippHemi is offline LX Padiwan
    Side to side rotation is unusual, unless you use the old "X" pattern rotation like we used to do with bias ply tires.
    You didn't mention what tires you have. Some are designed to rotate only one way. They generally have arrows pointing the right direction on the sidewall. Others have an outside and an inside.
    If all the torquing suggestions don't work. Try moving them back to the original positions. If it's all OK, then try rotating back and front on the same side and see what happens.
