Results 1 to 10 of 10
    345 RT's Avatar
    345 RT is offline LX Padiwan
    Hollywood, CA
    Red face 305-35-20's VS. OEM(STOCK)06'SRT8 RIMS
    HEY Y'ALL,
    I was just told that the Nitto's 555R 305-35- 20" Drag Raidials will fit on the back of The OEM (STOCK) 06' SRT8 Rims?
    I was told 275-40-20's are as wide as you can go with the stock SRT8 20's?
    Can you put the 305-35-20's on the back of your R/T, Charger, and 300c? Matbe a 3mm spacer?
    Any one that know about this could you help me out here. It would be much appreciated
    THANKS
    SON
    First LX Forum Member To Hit The 12 second Mark In The 1/4 Mile With A 5.7L Motor. Period.
    12-16-05@L.A.C.R. Palmdale , 12.947@106.08 ET, 1.909 60ft, 10.770 1000ft and .002 RT at 50 degrees
    Mods at time of run-GSM NOVI-1200 S/C SYSTEM, Dyno-Teck Long-Tube Headers, High-Flow Cats, a Borla Cat-Back System, and 18 inch BFGoodrich Drag Radials. L.A.C.R. R.I.P
    SIMPLY SOUTHERN
    Popeye's Hemi's Avatar
    Feb 2008
    Eastern Shore of Maryland
    [QUOTE=345 RT;2379025]HEY Y'ALL,
    THANKS
    One of our club members was running a set of 315/35-20 on 10" Viper Replica wheels on a 07 Charger.
    Another friend is running 305/35-20 Nitto DR's 555-R on a 08 Challenger SRT with stock SRT wheels. It's a tight fit but no rubbing, they fit in the wheel well nice. When I put the BC Racing coil-overs on the drop went 2" and then they started to rub a little. Re-adjusted to 1 3/4" on more rubbing.
    rander's Avatar
    rander is offline Just trying to make it in this world
    TX
    SON, these will smaller than your front tires, so just wanted to point that out. I saw a dude with these same tires in Houston a couple of weeks back and sure didn't like the look. Good tire though.
    Mine: 2012 Dodge White Charger SRT8 6.4
    Wife: 2012 Jeep GC Overland with Hemi
    Sold: Black 2012 Dodge Challenger SRT8
    Sold: Silver 2008 Jeep Grand Cherokee SRT
    Sold: 2006 Dodge Charger Daytona modded
    345 RT's Avatar
    Hollywood, CA
    Hey Y'ALL,
    So can the 305-35-20" Nitto Drag Radials fit on an SRT8 06' Charger wheel saetly?
    THANKS
    SON
    SIMPLY SOUTHERN
    dudeiwin86's Avatar
    dudeiwin86 is offline Dude...
    Houston, TX
    Quote Originally Posted by rander View Post
    ooooh burn!
    my fronts are 275/30 tho. seriously low pro,
    cant wait to change them, but hey, i got em free that way
    a 305/35 is only 3.25mm shorter sidewall than a 275/40/20. 3.25 mm is like..... close to nothing.
    Feb 2008
    Quote Originally Posted by 345 RT View Post
    Hey Y'ALL,
    THANKS
    SON
    The 08 Challenger SRT Stock wheel is 9" wide (I think) and the 305/35-20 Nitto DR is meant for an approved rim size of 10". But it will fit a 9-9.5 wheel and it looks good. The tire is 28.58" tall. I'm not sure what you are running on the front of your charger but I have 275/40-20 Vred's that are 28.68" tall, so I'm not sure why someone would say they are smaller than your stock fronts, well by a 10th of an inch Ok!
    dudeiwin86's Avatar
    Houston, TX
    Quote Originally Posted by Popeye's Hemi View Post
    this is correct. the factory forged SRT wheels are all 9" wide. front and read
    stevesrt8 is offline long term car nut
    Feb 2006
    sunny florida
    fits
    It'll fit, but it's not recommended.
    Probably going to distort it a little.
    Steve
    06 300C SRT8
    SRT8E85's Avatar
    SRT8E85 is offline Does the KorN smell good as I pass you!
    May 2009
    murderapolis
    yes they fit............................................... .................................................. ..............
    345 RT's Avatar
    Hollywood, CA
    Exclamation
    Hey y'all ,
    does any one in the greater charlotte nc area know of a place that widens rims?
    Thanks
    son
    SIMPLY SOUTHERN
