Results 1 to 13 of 13
    Tyrant is offline LX Newbie
    Bahrain
    275/40/20 on 20" daytona wheels, possible?
    Hi guys,
    Is it possible to put 275/40/20 tires on the stock 20" daytona wheels? anyone tried it?
    i want to get a new set of tires (need something with a bit more traction than the goodyear RSA's, thinking of toyos or the nitto innvo)
    your help would be greatly appreciated .
    2007 Charger R/T R&T, Mods - AFE stage 2 CAI, Kooks LT's and Hi-flows, Corsa Cat-back, MM ported throttle body, Diablo 91 canned tune (+3.5% fuel), R1 rotors, Centric Posi-quiet Ceramic Pads, SRT rear diffuser, Avic F700BT, CBD CF SRT-8 Hood, 5000K Dabears HID's (lows/fogs), almost everything BT offers for the Charger (lol)
    best 0-60 (so far) 5.30
    http://www.lxforums.com/board/signaturepics/sigpic10034_1.gif
    89grand's Avatar
    89grand is offline LX Guru
    Phoenix, AZ
    What are the width of them, 8.5", 9" maybe?
    Either way you should be ok. People run 275/40/20's on 8.5" wheels, although that's probably the maximum for an 8.5" wheel.
    2000 Jeep Wrangler
    1966 Dodge Monaco 500
    Fahad R/T is offline LX Newbie
    Jun 2006
    Bump bump bump...
    doublescharger is offline LX Newbie
    Hey everyone, I tried to put Nitto Invo 275/40/20 on my Daytona. It has the same wheels as yours only black. They rubbed in the front so I went with the 255s instead. The 275s did look sick, but didnt work with the stock wheels.
    dumpster's Avatar
    dumpster is offline rock and rolla
    Feb 2007
    zion, illstate
    just run the 275's out back
    high888's Avatar
    high888 is offline LX Padiwan
    Nov 2005
    Tampa, FL
    You can put 275/40-20 all the way around on the SRT8, which has a 9 inch
    wide wheel, and also a different shaped control arm which runs from on top
    of the wheel/tire and curves around and down the back side. Much more room. With your setup it most likely would rub, and the wheels are not wide enough.
    Bahrain
    Quote Originally Posted by doublescharger View Post
    hmm interesting.. i personally want to only put them in the rear.. did that work or did the tires not fit?
    89grand's Avatar
    Phoenix, AZ
    The 275 tire fits just fine in the back, and in the front too...well except for doublecharger I guess.
    The 275 will absolutely fit in the back.
    2000 Jeep Wrangler
    07RTLOVER's Avatar
    07RTLOVER is offline LX Padiwan
    Nov 2007
    Issaquah Washington
    Hey Gang, I am running 295\40 on my rear Daytonas, and they work great. They will rub in the air but set her down and no rubbing what so ever. And they don't look all bowed out either. I couldn't be happier.
    moonstreaker is offline LX Guru
    NJ
    If you are only going to use 275/40's in the back you should run 245/45's up front. If you run 255/45's up front your car will look goofy as hell running taller tires in the front than in the rear.
    89grand: you have an offset wheel as shown in your signature. Tyrant is trying to use the stock Daytona wheels.
    The 275s fit in the rear, not when the car is in the air, but on the ground no problem as said before. In the front with the Daytona wheels they rub the control arms. 255s work and look great.
    89grand's Avatar
    Phoenix, AZ
    Yeah, I wasn't trying to say that you didn't have rubbing issues, but it seems as though I've read a number of posts with people running 275's all the way around even on stock wheels, but maybe I'm wrong about that. Maybe they were all SRT8's.
    2000 Jeep Wrangler
    Bahrain
    07RTlover, really the 295's fit!.. must lok good from the back.. any pics?
    btw guys my plan is to keep the 245's up front and 275's in the rear for a staggered look also to get a little more traction on our messed up roads.. mashing the pedal from 25-40mph will on most roads send me sideways! plus the look you get from wider rear wheels just fits the car so well
    Thanks for all the help guys, now to go burn some rubber off those 245's lol .
