Results 1 to 12 of 12
    high888's Avatar
    high888 is offline LX Padiwan
    Nov 2005
    Tampa, FL
    255/55-18 don't rub on the steering knuckle?
    I would think that with a 29.1 diameter and 10 inch width, they would be rubbing against the steering kunckle bar behind the tire, back under that bolt.
    Those stock 18" wheels have a 24mm offset. And those BFG's look REALLY fat.
    No issues?
    MagnumFreak's Avatar
    MagnumFreak is offline Chasing Dreams
    Jun 2004
    Evans, GA
    Nah, I am running 255/55 18's (Toyo Proxes ST) with no issues. There is plenty of room above the tires and below the knuckle. The knuckle is on the outer edge of the tire so expansion under speed is not an issue. I have testing the speed limiter with the tires and had no rubbing.
    2005 Dodge Magnum R/T
    -Martin Luther King, Jr.
    lilguyhemi's Avatar
    lilguyhemi is offline Beer Wagon
    Jul 2004
    Tucson, Arizona
    I am running Michelin 255/55 18 tires and have no issues.
    Hemi Registry # 126 14.79 quarter
    Other car: 1967 Dodge Dart GT 340ci
    FEATURE CAR Dec 2007
    Hemmings Muscle Machines
    Northern Rider's Avatar
    Northern Rider is offline Move Over People Are Racing
    May 2005
    Ottawa, On
    I am running BFG KDW2's (in the summer).
    Clearance is fine. Might get a pinkie finger in there.
    The real test is running a road circuit at high speeds. I ran a full day of performance lapping at LeCircuit Mont Tremblant early in October.
    Tire pressures were set to 44 lbs psi cold and were higher hot. The tires never rubbed at any point.
    The handling with these tires is awesome! They also deliver a very comfortable ride.
    Never give the competition an inch
    zonian's Avatar
    zonian is offline LX Padiwan
    Jun 2004
    Bloomingdale, IL
    255-50-18's Toyo Proxes ST here on stock R/T RWD rims.....no rubbing either
    Paul
    My wife says I never listen to her...or something like that.
    OA-5599's Avatar
    OA-5599 is offline Vanishing Point
    Denver, Colorado
    Quote Originally Posted by Northern Rider
    Ditto on mine, no probs. Go for it!
    2005 Magnum R/T; Hemi Registry #178
    Vortech SC, Dynatech Longtubes, Cats, Aeroturbine Exhaust, Body Mods
    Silver1's Avatar
    Silver1 is offline disLXic
    Ketchum, Idaho
    Here is a pic of the clearance on an 05 Magnum RT AWD with 255/50-18 Toyo Proxes S/T's.
    MAGNUM8R's Avatar
    MAGNUM8R is offline Yes I am a pirate, 200 years too late
    So. California
    The BFG KDW in 255/55/18 are a bit closer than pictured. The real tight clearance is the vertical portion of the steering arm, I measured .180" on mine!!
    No rubbing, hang on though, they really corner, add about .4 G's to what the Conti's do in a corner!!
    An over 40 victim of fate.
    '8R'05 Magnum RT Midnight Blue Pearl
    KW V 2 , Hotchkiss Sway Bars, CF Airhammer intake,T Rex Billet Grille, Body color Airtab Vortex Generators, Chromed stock 18's BFG KDW 255/55/18 Tires,Avon splash guards, Gibson Performance Stainless SteelHeaders, GibsonCat back, SC 91 Performance tune.
    Hi Flo Cats
    kudasai's Avatar
    kudasai is offline medium pimpin
    Oct 2004
    an jung ri, south korea
    255-55-18 sumitomo's. no rubbing here
    05 magnum rt
    83 300TD with waste veggie kit
    92 nighthawk 750.
    burn vegetable oil to work, burn rubber on the weekends!
    moparman53's Avatar
    moparman53 is offline Finally got a HEMI again.
    Nov 2004
    E Williamson Co, Central Texas
    Question
    Quote Originally Posted by Silver1
    Don't see any pic?
    Silver1's Avatar
    Ketchum, Idaho
    Quote Originally Posted by moparman53
    Don't see any pic?
    Sorry! I had to pull it to post another pic. Here it is again...
    Padre Dave's Avatar
    Padre Dave is offline Hemi drivin' Pastor
    Tucson & Chandler, AZ
    Quote Originally Posted by lilguyhemi
    Me too...must be a Tucson thing, eh?
    The Lord bless and keep your coming and going!
    Padre Dave
