Results 1 to 13 of 13
    jules2315's Avatar
    jules2315 is offline 2006 RT
    Calgary,AB,Canada
    Question 22's rub...only in reverse??
    I just put 22's on my car and the tire size is 265/35/22 and they rub in the front only when i am in reverse and turning. Does anybody have any info that could help me out for a fix for this problem or any ideas??
    Much appreciated all.
    Cheers
    HemiPowered5700's Avatar
    HemiPowered5700 is offline Raging Inferno
    Mar 2008
    Chi-Town
    265/65/22???
    That's a little bit tall for our cars I believe...
    2006 Dodge Charger R/T
    2000 Mercedes E55 AMG
    1991 Cadillac Fleetwood 4.9L FWD
    HULK's Avatar
    HULK is offline West Coast Style Meets East Coast Power
    Aug 2007
    Chicago, IL
    Thanks for that useless comment steve, clearly it was a typo.... Tires like that would be pretty hard to come by!
    I assume you meant you have the 265/35/22 tires. If you are having issues in reverse, it is likely a problem with the offset/size of your wheels, not necessarily the tires themselves. Some people have solved this problem with the 3mm spacer on the fronts to stop the rubbing. I havent looked into this problem all that much, but I know most people have had luck fixing it.
    Dont worry though, you arent alone with this issue. Im sure someone who has experience this first hand will chime in with a fix for you. The offset of my wheels is +18 and Im running the 265/35 tires and dont rub at all, what is your offset? Any idea?
    -Pat
    Quote Originally Posted by Simans82 View Post
    Compared to your modding addiction, I'm just looking at the coke on the table. You on the other hand, you're more like Scarface.
    Mar 2008
    Chi-Town
    Don't listen to anything Pat says.
    That is all.
    jules2315's Avatar
    Calgary,AB,Canada
    my offset is 15mm, they came of a Charger as i bought them slightly used.
    Yes it was a typo...
    HULK's Avatar
    Aug 2007
    Chicago, IL
    Yeah Im willing to bet that more likely than not, all you need is the 3mm spacers for the front wheels and you'll be good to go. Look into finding a set of those, shouldnt be too expensive or anything. Let me know how it goes.
    -Pat
    jay2g1's Avatar
    jay2g1 is offline Silence Your Enemies With Success!
    Oct 2005
    Maryland
    also you may want to make sure they did not put the wieghts on the lip of the rim, I had a friend who had a set that the weight rubbed in the front because they put them on the inner lip. probably not the problem but just my 2 cents.
    2005 Magnum SE - Gone
    2006 Charger R/T - Gone
    2008 GCSRT8 - Current - 11.42@117.27
    Magnacharger & Exhaust Only
    viper3ez's Avatar
    viper3ez is offline Hello, my name is Nuvie.
    Jul 2007
    Bronx, NY
    a lot of us had the same problem.
    3mm spaers are ur solution.
    my wheels came from a magnum without tthe issue but i had the issue.
    i got my spacers from bones ent.
    Quote Originally Posted by gr8crash View Post
    Its like paying $6K for your girlfriend to get a great boob job, then meeting a girl that has better boobs that are natural, are you gonna complain cuz you paid $6k for boobs for an Ex that aren't as good as the one in your hand? I think not.
    jules2315's Avatar
    Calgary,AB,Canada
    i appreciate all of the help with this. Will look into spacers.
    Cheers
    Valleybull's Avatar
    Valleybull is offline Valleybull
    Aug 2007
    Halifax, Nova Scotia, Canada
    What is it rubbing on? For me the rubbing was on the inside edge of the tire, against the control arm. I had to go with 7mm spacers for mine to clear. I have the same size wheels tires as you, but with a 20mm offset.
    Valleybull
    2005 Magnum RT RWD
    K&N FIPK Air Intake
    Tint
    22 x 9 Moz Nooners w/ Nitto Tires
    Blastin Bobs 9db Resonator Delete
    HULK's Avatar
    Aug 2007
    Chicago, IL
    ^^^ Your issue could be related to the fact that you are running 9" wide rims. That changes the situation, and thus offset cant be applied similarly to someone with say, a 9.5" wide wheel, which tends to be the more commonly run size on these cars. Just my opinion....
    Every wheel and tire setup is different though, but Im willing to be a 3mm spacer will solve this case, as others have also suggested.
    -Pat
    viper3ez's Avatar
    Jul 2007
    Bronx, NY
    i'm running 10" wheels in front.
    3mm does the trick
    jules2315's Avatar
    Calgary,AB,Canada
    awesome info guys!! have checked with Bones and the 3mm spacers ar $60 + shipping. Will give them a try.
    Thanks again from your neighbor to the North!!
