Results 1 to 2 of 2
    MMmagnum is offline MMmagnum
    Aug 2005
    Brandon
    Cool 22 Rubbing Upper Arm
    I have a 05 RT with 22's. My front pass. side tire is rubbing the upper arm on the inside of the tire. Driver side seems to have enough clearance. I noticed this after i had a flat tire. I have a full size spare with a brand new tire, it rubs and touches the bolt so I swapped the front and rear and the inner tire is rubbing but it clears the bolt. Is this a strut issue? What is the cheapest what to fix it. Or is this a good time to lower it.
    NVRDUN's Avatar
    NVRDUN is offline LX Guru
    Las Vegas
    If I remember correctly some people with 22"s and larger have to grind down that bolt a little bit. I dont know if it has to do with tire size, offset or just manufacture differences between cars?
