Results 1 to 15 of 15
    08chagerlopez is offline LX Newbie
    Jul 2009
    22 inch 265/35/22's on my SE PLUS charger
    i put some of these on my charger... should i move down the tire size 265/30's? the 35's look really close to the bar that has the bolt on the end... i bought these from someone who had them on their charger but it still seems like a tight fit. not much room on the inside of the front tires and the bar with the bolt that hangs over the tire ( not sure what bar this is ). felt the inside of the rim and it seems pretty tight up there as well... is there anything i can do about this? should i move to 265 / 30's ?
    lowryder99 is online now LX Padiwan
    Apr 2009
    Edmonton, AB
    If it's not rubbing I wouldn't worry about it, that bolt use see directly above the tire moves with the suspension so it will not hit the tire.
    krewkut125's Avatar
    krewkut125 is offline LX Newbie
    Apr 2009
    Yea the bolt is fine. As the guy above said the tire and the section where you see that bolt all move as one so it will never hit. As for the space you have behind your wheel do you know what offset they are? (they are printed on the back of the wheel. If you have a +15 - +18 you are golden and will have no problems.
    06RTBLK is offline LX Newbie
    Aug 2009
    Goodyear
    Quote Originally Posted by lowryder99 View Post
    I have 265/35/r22s on an 06 rt and the bolt does hit the tire I have a perfect groove on the inside of the tire where the bolt is.
    SXT6's Avatar
    SXT6 is offline ///RA - Nation's Finest
    Feb 2009
    TN
    Quote Originally Posted by 06RTBLK View Post
    I smell other problems....there are thousands who have a 265/35 and never touch. Like me
    EvoATL's Avatar
    EvoATL is offline BlackMag
    Jan 2009
    ATL
    Quote Originally Posted by SXT6 View Post
    x2
    05 Magnum RT - SOLD!
    08 Challenger SRT8
    RIDES | CARMA
    Hemi RT's Avatar
    Hemi RT is offline ?????
    Jul 2007
    Medicine Hat, Alberta
    It's been bugging me, what's a SE Plus Charger?
    Hemi Registry #00730
    SXT6's Avatar
    Feb 2009
    TN
    Quote Originally Posted by Hemi RT View Post
    Just an SE with some more options. Believe it has the 3.5, and maybe some other upgrades like the 6 disk changer and such
    Aug 2009
    Goodyear
    Was out in the garage today have the car jacked up with tires off i cant see anything wrong. Went over all the bushings,suspension. What could be causing this then?
    SXT6's Avatar
    Feb 2009
    TN
    Only thing I can think of off the top of my head would be way too much pressure in the tires....but I wouldn't even think then that it should, maybe someone who knows a little more will chime in because I've never heard of anyone with that problem
    Nightshade's Avatar
    Nightshade is offline LX Guru
    Kitchener, Ontariooooo
    x3 (and I am lowered a couple of inches now)
    hemicanucksfan's Avatar
    hemicanucksfan is offline so many projects, so little money
    toronto area (ajax)
    265/35/22 with no issues at all.
    2010 LX&Beyond Nat'ls Best In Show Magnum Daily Driver
    2011 LX&Beyond Nat'ls Best In Show Magnum Weekend Driver
    2-toned, trufiber srt hood, 22"x9.5" gray Foose Nitrous, colour-matched headlights w/halos, 6000K HIDs (lows/fogs), tinted marker lights, colour-matched fog bezels, tinted tails, Airhammer, Eibach Pro-kit, Predator, Edelbrock headers/cat-back, jba hi-flow cats, 82*C thermostat (180*F), remote start, MDS indicator, Mopar hitch. So far.
    Jul 2009
    been driving with mine for about a week... i THINK i have slight rubbing isssues with the front tires rubbing the backside on the bar BUT i ordered the 13mm billet spacers which should clear it up... ill post pics of car and tires once im done. only other problem i have encountered is the ABS turning on with a slightly hard stop. used to take a bit of sliding to kick it on BUT i think the rims and tires are just heavier.
    SXT6's Avatar
    Feb 2009
    TN
    Quote Originally Posted by 08chagerlopez View Post
    THAT rubbing is an offset problem, the spacers should fix that
    DEEP3R's Avatar
    DEEP3R is offline DEEP3R in your pockets
    Dec 2007
    Mounds View, MN
    I run those tires with no issues at all
