So I'm looking at picking up drag rims and 275 wide DR's, and I've found a good deal with 17x9 24mm. Based on what I've found out, there is 19mm of less clearance on the inner side, and it will stick out 19mm. I have no problems with the outer clearance, and I went under the car check it out.
It looks like I should have no problem with the rear assembly, but I did not check the angle of the spring perch, etc.
Am I going to run into problems?
Thanks!
2006 Inferno Red Magnum RT - 12.9@107.5 at TMP DA 300 Sept 28, 2012,
SRT headers, Magnaflow 3" catback w/ hi-flows,Mopar CAI, Diablosport Trinity, Stant 180 deg thermostat, Inertia Spartan Cam, 6.1 chain tensioner, B&M transmission cooler, FTI 3200, MTCM, 392 swaybars F + R, Eibach Pro-kit, 6.1 heads, intake, 2012 3.91 Getrag, OST tuned, Joelvan rad, Brembos
To be installed: PS cooler and engine oil cooler
If thats a cobra replica style rim, 17"x9" with 24mm offset and 6" back space you should be fine. As long as it's a five lug![]()
Haha yes, five lug, but it is not the Cobra style, it is the FR500 style.
And it does have 6" of backspacing. I may just make the plunge!
