Has anyone ran some 17x10.5 with a 27mm offset? Just checking before i spend the money and run into a problem.
N/A 6.1 Heavy Weight Champion 11.11@126
HHP Stage 2 Always Imitated Never Duplicated
I found some replicas cobra wheels.
so any luck with the wheels?? If so what wheels are they and what size tire you runinng?
07 MSRT8, Techco blower, custom exhuast by me. 514whp 490tq
03 Lancer Evolution, in the procees to see 700whp
03 Ram 3500, lifted, stacked chips
99 Dakota R/T, full out drag truck, the 740hp 360 is out and the engine bay is waiting for its 440
myspace.com/xxxevoviiixxx
No luck too much back spacing on those wheels our car can't take no more than 6'' with 26mm offset. Those wheels almost has a 7'' . I'm gonna just run the stock cobra r with with the 315/35r17 BFG's it bows out a little bit. I wouldn't use that setup to autocross or any thing , but we'll see if it makes a difference at the drag strip.
No i need to find a set up for the track. So that set up clears with no rubbing?
American Racing makes a 17"x9" wheel called the razor in our bolt pattern. I just got back from the wheel shop with them all mounted up to my 275/50 M&H's. They have a 6" backspacing and clear the brakes and sway bars just fine. Cost was 169$ per wheel.
whats our bolt pattern?
Jim "Meister" Edwards
RIP "SLICK"
5x115mm
