Pricing of cam packages
PRICING RELEASED!!!
We've been going around and around on these packages. Nailing down the easiest and quickest path for installation which means working to get the pricing down as low as possible. Here's our different naturally aspirated packages as we've laid them out. Below each package is the "overlap" labor for mods that are typically added on at this time, too.
MANUAL TRANSMISSION PACKAGES:
(1) SMALL CAM ONLY: Smaller Comp Cam for use with stock springs, Comp Phase Limiter, Professionally installed and dyno tuned by HHP: $2,575
ADD $600.00 Additional Labor for Long Tube header install with this package
(2) BIG CAM & SPRINGS: Big Comp Cam, Manley Springs, Manley Ti Retainers, Manley Spring Locators, Comp Phase Limiter, Professionally installed and dyno tuned by HHP: $3,700
ADD $150.00 Additional Labor for Long Tube header install with package
(3) PORTED HEADS & BIG CAM: HHP/BES Ported & Polished Cylinder Heads, Big Comp Cam, Manley Springs, Manley Ti Retainers, Manley Spring Locators, Comp Phase Limiter, Gaskets & Bolts, Professionally installed and dyno tuned by HHP: $6,050.00
ADD $0.00 Additional Labor for Long Tube header install with package
AUTOMATIC TRANSMISSION PACKAGES:
ADD $600 Additional Labor for Long Tube header install with this package
ADD $600 Additional Labor for Torque Converter Install
(2) BIG CAM & SPRINGS: Big Comp Cam, Manley Springs, Manley Ti Retainers, Manley Spring Locators, Comp Phase Limiter, MOPAR MDS Lifter Delete, Professionally installed and dyno tuned by HHP: $3,950
ADD $150.00 Additional Labor for Long Tube header install with this package
ADD $300.00 Additional Labor for Torque Converter Install
(3) PORTED HEADS & BIG CAM: HHP/BES Ported & Polished Cylinder Heads, Big Comp Cam, Manley Springs, Manley Ti Retainers, Manley Spring Locators, Comp Phase Limiter, Gaskets & Bolts, MOPAR MDS Lifter Delete, Professionally installed and dyno tuned by HHP: $6,300.00
ADD $0.00 Additional Labor for Torque Converter Install
IMPORTANT NOTE: These packages are under the assumption that you have a Diablosport Predator, InTune or Trinity. We also recommend a 180 thermostat, a good CAI and exhaust upgrades to get the most benefit out of these packages.
We're officially ready to roll!![]()
Check us out online at www.HighHorsePerformance.com
Pick up the phone and call us toll free at 888-894-1115
Email us at sales@highhorseperformance.com
I'm pretty sure I missed this somewhere, What power levels are we talking with these packages?
MODS..AFE II, DIABLO PREDATOR,SRT EXHAUST,INERTIA HEADS AND SPARTAN CAM(BOB@SVS TUNED)
>>>>>>THIS IS SPARTA<<<<<
i made 454 hp and 422 tq with just the cam...............................john
That's a lot of HP for just a cam, that's amazing....
