Introducing the first complete bolt-in return style fuel system for the HEMI Cars!
Here's our direct links to these kits:
Our Complete Dual and Triple Walbro Fuel System kits are designed to give HEMI owners the FUEL PRESSURE and VOLUME needed for higher horsepower applications. We've incorporated Fore Precision Works full line of HEMI fuel system products into our complete setup and we've done the hard work of sourcing all of the required pieces needed to install this package with ease, saving you valuable time and money. Fore Precision's billet fuel hat is by far the best product on the market of it's type, and the quality of Fore Precisions fuel rails, in-line fuel filters and fuel pressure regulators (F1 included, 1 yr warranty) are the best we've seen. All manufacturer warranties apply! Since the factory single-feed fuel line cannot support the fuel volume requirements of higher horsepower applications, the need for a regulated return-style system with much larger fuel lines is a must in order to not damage your engine. These kits are designed to make them the most complete kit on the market!
Applications:
2008-2010 5.7L & 6.1L HEMI Dodge Challenger
2006-2010 5.7L & 6.1L HEMI Dodge Charger
2005-2008 5.7L & 6.1L HEMI Dodge Magnum
2005-2010 5.7L & 6.1L HEMI Chrysler 300C
Kit Includes:
- Fore Precision Works Billet Fuel Hat
- Required Walbro GSS-340 Fuel Pumps & Socks
- Fore Precision F1 Fuel Pressure Regulator
- Fore Precision In-Line Fuel Filter
- Fore Precision Billet Fuel Rails
- All Required AQP Fuel Fittings
- High Strength Steel Hat Fittings Under Seat
- 0-100 psi Fuel Pressure Gauge
- 20' -8 Fuel Line
- 20' -6 Fuel Line
- Required Relays & Fuses w/ LED Smart Glow Fuses
- HD Zip Ties for line mounting
- Heat Shrink, Assembly Lube & Teflon Tape
- Complete Installation Instructions
Availability: Ready To Ship Now!!!
Upgrades are available for this kit. Just give us a call at 888-894-1115 for a full price quote with any upgrades you may be interested in. If you already have parts of the system, we can build you a custom kit around what you already have.
Available Options:
Black or Clear Fuel Rails & Fittings
Available Upgrades:- F1 to F2 Fore Precision Fuel Pressure Regulator +$50.00 (3 Year Warranty)
- Carbon Steel to Stainless Steel Hat Exit Fittings +$62.25 (Additional Corrosion Wear)
- Viton O-Ring Upgrade for Fuel Filter +$9.00
- Positive Pressure Relief Valve On Filter Inlet +$50.00
- Hobbs Switch, Pressure Activation Sensor +$54.09
- 12" Teflon Line Extensions w/ Fittings +$53.85 (Helps to Prevent Fuel Line Breathing Under Rear Seat)
Give us a call at 888-894-1115 if you have any questions.
Below are several photo's of our two pump kit on a 93 Octane 700 rwhp 426 D1SC ProCharged (12psi) 6-Speed Challenger SRT-8 we completed a few weeks ago. This test car tuned up perfectly with this kit and then left for a cross country trip from here on the East Coast all the way back to it's home in New Mexico at 7000' elevation. This kit has performed flawless!
