Results 1 to 15 of 21
Like Tree6Likes
Thread: Dyno Results: VVT 5.7L Camshafts... 100+ RWHP Gain
    HighHorseman's Avatar
    HighHorseman is offline #1 Distributor of LX Performance Parts
    Feb 2005
    Smyrna, DE
    Thumbs up Dyno Results: VVT 5.7L Camshafts... 100+ RWHP Gain
    We tested Comp Cam's new HEMI Phaser 274 camshaft with their phase limiter to see what was possible with a real camshaft in the VVT. This is the largest camshaft Comp offers.
    The test car was a stock engine 2009 5.7L 6-Speed R/T with our 1 3/4" Kooks long tubes, high flow cats, Corsa cat-back, AFE intake, 180
    tstat.
    We installed:
    Then we tuned her up on our dynojet. You'll hear a little clunking through the gear shifts since the driveline is stiff and has no clutch slippage thanks to a racing clutch from Spec and our fully built T-6060 transmission, one-piece driveshaft from TDSS, upgraded rear and axles along with our GNK Hurst shifter with MOPAR short throw shifter arm. There's zero play in the driveline on this car, lol.
    Dyno w/ Results Link:
    Idle Clip:
    The info we've been able to get off this test now allows us to go back and pick apart the gains. Our cam designer at our engine shop, Tony Bischoff of BES Racing Engines, is reviewing the data and custom camshafts will be released shortly. If he doesn't think we can make any improvements to NA stock engines, we'll stick with these profiles from COMP which are really good. At a minimum, we will have custom profiles to release for forced induction and nitrous applications shortly.
    For you guy's coming in this Saturday to our Open House at the new Delaware shop, we'll have the car here for you guy's to listed to. She sounds SICK!!!
    Joshua, HHP
    www.HHPRacing.com
    The Official Home of the Most Powerful Modern 5.7L, 6.1L, 392ci & 426ci HEMI Engine Packages.
    The Leader In LX Performance Parts & Installation
    Check Us Out Online & Contact Us Today At 1-888-894-1115
    Serving the members of this forum since 2004.
    6speedrt's Avatar
    6speedrt is offline Tire Puller
    Nov 2010
    wilm.de
    that shore is a nice car.i bet its a fun ride too.lol..........................john
    Williescott2 is offline LX Newbie
    Apr 2011
    I wonder what it will do to a 6.1?
    Sent from my SGH-T989 using Tapatalk
    1FST4DR's Avatar
    1FST4DR is offline I just dont get it...
    Ft Laud.....
    Quote Originally Posted by Williescott2 View Post
    Totally different engine . This is about the VVT motors..
    TanT's Avatar
    TanT is offline <~Eat Me!
    Jun 2009
    Baton Rouge, La.
    I think he meant that car versus a 6.1L car in a race...I think.
    Name is Kyle aka Dookie 2006->BB->Charger->SRT8->426->:-)
    Quote Originally Posted by Hemi31
    Told ya. .....
    Quote Originally Posted by Dreadl0ck
    But it's not criminal to be an asshat.... Just not beneficial to you
    plumfloored's Avatar
    plumfloored is offline Supporting Vendor
    Mar 2008
    Great numbers, well done!
    dejuan71 likes this.
    Plum Floored Creations
    For hemi swap information
    Start Enjoying $4+ Gas!
    Grip Tuning, Black Ops, SLP Performance Products, Mopar Performance, ACE Alloys, Toyo Tires, Razors Edge, Escort, Paramount Performance, Sinister Extremme, MOPARKC.COM,
    Feb 2005
    Smyrna, DE
    Thanks guys!
    6speedrt's Avatar
    Nov 2010
    wilm.de
    no thank you,all i got say is this thing is nasty trew the gears,pulls power past 6500.lol.....i might need a nother set of new rear tires soon.
    so whens the ported set of heads going to be out...maybe we can get 500hp at the tires....this cam is a great upgrade.i can just leave the juce at home.......................john
    Feb 2005
    Smyrna, DE
    Update:
    Ok, so far we have two solutions for making this package easy for installation of the valve springs that are needed.
    Option 1 is we can put the package together with a Manley valve spring, retainer and spring locator combo that is made just for the 5.7L heads. For you guy's wanting to rush to do this package, we can release it right now with this setup from Manley. The cost for these Manley parts is $586.40 and they are available today.
    Option 2, which is the way that we will be doing it under the HHP name, is going to take a few weeks for Comp to make us new spring locators in a predetermined thickness which will allow us to use our preferred spring of choice and retain the factory spring cage which is there to keep the valve from dropping incase you ever break a valve spring. Bischoff will be providing the thicknesses to Comp early next week when he gets some parts in from us we just had to order up today and they should run with it pretty quickly. This second option is our preferred method.
    Valve spring selection is something that we spend a lot of time on since at the end of the day, a $12.00 part carries a potential to fail and this can be catastrophic in your engine. Back when the Gen3 HEMI first came out we, along with our competitors that were around back then, went through a handful of valve spring failures in our first years with several manufacturers of springs and several blocks took pistons through the side-wall. We're dotting all of the i's and crossing all of the t's to ensure that your risks are minimized since the VVT engines can only be replaced by purchasing a long block from Chrysler and the cost is relatively high. The warranty on a race part is that you'll probably get the broken part replaced but you won't get whatever additional parts gets damaged as a result covered. You break a valve spring and here's a new $12 valve spring but you're left paying $5k for that new engine. We don't want a repeat of what happened when we first went down this road years ago. We have a combination that has performed flawless for us for years now, and option 2 will allow us to use our combination we feel comfortable with.
    All that being said, risks are assumed by the customer and we (HHP) do not insure aftermarket parts in your engine even if we do install them. We just guarantee that they were installed correctly. We do everything in our power to put a combination together to minimize your risks.
    If you are interested in this package, please email me at josh@highhorseperformance.com and I will get back to you as quickly as I can.
    Thanks!
    Joshua, HHP
    Feb 2005
    Smyrna, DE
    Next up, it will take us a short while to get a set of heads ported by Bischoff but we will be testing out our BES line of ported heads on this test car in the next couple of weeks to see what the additional gains are. Stay tuned on this!
    1FASTSOFA's Avatar
    1FASTSOFA is online now Gear Head Without a Cause
    Jan 2012
    You guys gained almost 100whp with just a cam, headers, and a tune?!
    1FASTSOFA's Avatar
    Jan 2012
    how much power can be made without the long tubes and on an automatic?
    only other mods will be just a cold air intake and 180 thermostat...
    kar1zma is offline LX Padiwan
    Apr 2009
    updates on this
    dejuan71 is offline LX Guru
    Sep 2008
    Kansas City, KS
    Whats the difference in gain with the VVT vs the previous years? Heads and what else? Never thought id see that high of a gain on a 5.7.
    GreenGoblin V6 to VVT 5.7 Hemi Swap by PlumFloored
    best e/t 12.96 at 107
    Mar 2010
    Elk Grove Village
    Whats the deal here? Any more updates to this ride or was it a major failure hence the lack of posting on this??
