Results 1 to 15 of 15
    HR2PRTY's Avatar
    HR2PRTY is online now LX Padiwan
    Feb 2009
    San Diego
    ESP completely off
    Ok so I have hear that you can install a switch that can turn the ESP all the way off without killing the traction control or ABS. I guess there is a gyrometer under the center console that controls the computers yaw reading for the esp system. If you put a switch on the power wire for that gyrometer you can kill esp while keeping abs and other systems working. The basis is that the computer thinks the sensor is bad and turns the system off. Theoretically then you can flip the switch whenever you want to kill esp.
    Has anyone done this? Does it work? And how difficult is this to do myself?
    Thanks
    NC-SXT's Avatar
    NC-SXT is online now purveyor of fine custom grilles
    NC Coast
    I thought the srt could kill it anyway (press and hold the button down). But yes there is a write up by rtjunkie on doing this with a switch.
    Read here http://lxforums.com/board/showthread.php?t=45309
    WWW.DodgeMagnumGrille.com
    liljoejoe54's Avatar
    liljoejoe54 is offline LX Padiwan
    Sep 2007
    Chicago
    I have done it and yes it works and works great! It is very easy to install and shouldn't take more than 30 minutes to do.
    MOL SRT-8's Avatar
    MOL SRT-8 is offline SHOW & PERFORMANCE
    Dec 2006
    SAN DIEGO, CA
    sdcarguy had it in his car for awhile. you can turn it off with the preditor also.
    WWW.SHOWANDPERFORMANCE.COM
    SoCalLX
    Congratuation Del Worsham
    2011 Top Fuel Champion
    Asrtive is offline LX Padiwan
    Dec 2008
    Orange county ca.
    I had GSM do mine it works great also has a fan switch
    Airaid CAI~180 t~stat~Diablo CMR Tune~Kooks Long Tube Headers~Hi Flow Cat's~MagnaFlow Exaust~Esp fan mod switch~Stagered~Ruber~Stack Performance~Intake~Manifold~Spacer~Pinstripes.DMH e-cutout's
    FloridaRT's Avatar
    Ocala, Florida :-)
    I did the RTJUNKIE ESP switch mod, there is a write up here with pictures somewhere, search for it.
    Downside is that you just can't flip the switch back on to restore ESP, you must shut off engine, then flip the switch back on.
    Other then that, it works fine.
    Bob
    charginscott's Avatar
    charginscott is offline LIVING A DREAM
    Alvin, Texas
    Then there is the NO-ESP mod that someone sells.
    http://noesp.com/
    edit: just saw you have a SRT, NO-ESP doesn`t work on SRT
    "DETONATOR"
    Sidewinder numbers
    1/8 8.45@82.90
    1/4 13.14@107
    Certified AAC Houston Installer
    Jontoad's Avatar
    Jontoad is offline mopar or no car
    Feb 2008
    Naperville, IL
    i think I'm the one who told your friend Kevin about this on the dakota r/t forums. get some 18 guage wire from radio shack, a switch, and some butt connectors. then just tap the purple wire with the light blue stripe on it under your center console. (not the purple with dark blue stripe.)
    Quote Originally Posted by NC-SXT View Post
    the srt dash still cuts power to the motor when you get sideways even in full off position. if you cut power to the gyro-meter it wont do that.
    Quote Originally Posted by charginscott View Post
    http://noesp.com/
    it does work on the srt i have it on mine. just put a switch on the power wire for the gyro sensor. the purple wire with the light blue stripe.
    Quote Originally Posted by MOL SRT-8 View Post
    if you use the predator it puts the car in limp mode if you make a u-turn or turn the wheels too far because predator disable is actually "emissions dyno roller mode" and it freaks out and thinks your crashing on the dyno if you turn the wheels too far. don't drive around on the street with esp disabled with the predator or you will into limp mode on sharp turns.
    2006 black /SRT//8/-
    12.521 @ 112.263 MPH corrected time
    - second place SRT8 shootout great lakes dragway 2008
    - autocross vids...http://www.youtube.com/watch?v=CjQeby5cB1Q / http://www.youtube.com/watch?v=v0So5e-GGXM
    EXTREME's Avatar
    EXTREME is offline Yes, that is my fast driving award.
    Oct 2005
    Flowood, MS
    With the switch on the gyro, can you switch it off and leave it off? So that it will disable on each startup!
    Also, can a momentary switch be installed, So all you have to do is push the button, kill power for a second to disable the esp. Then you don't have to remember to turn the switch back on the next time you start it!?
    US Wheels - Frank Racing - AirHammer - Corsa - AirLift
    22Elite - Billet Tech - 3B Spec HIDs - Diablo Sport
    JT/NoESP - Llumar - Stealth Auto - NavHack
    12.69 @ 109.65
    FloridaRT's Avatar
    Ocala, Florida :-)
    Quote Originally Posted by EXTREME View Post
    Yes, you can leave it off................
    No need for a momentary switch, just flip the switch to off (car running) and then back to on, the ESP will stay off until you restart car.
    Bob
    wolfmann21's Avatar
    wolfmann21 is offline heavy foot, loose ankle...
    Aug 2008
    Ajax,Ontario
    on my mag RT R&T i have an esp button on the dash.just push it to turn it off, push it again if i want it back on.i thought all RT's had it...was it only RT R&T's?
    sry not to hijack or anything, just curious now lol
    EXTREME's Avatar
    Oct 2005
    Flowood, MS
    Quote Originally Posted by wolfmann21 View Post
    that button on the dash does not turn off the esp completely. Moreso on the SRT models but never 100%
    12.69 @ 109.65
    EXTREME's Avatar
    Oct 2005
    Flowood, MS
    Quote Originally Posted by FloridaRT View Post
    Bob
    Thanks for the info Bob!
    12.69 @ 109.65
    gooeytek's Avatar
    gooeytek is online now heavy hemi
    Jun 2008
    Lake Grove, NY
    i use a momentary switch, for the reason you stated earlier.
    http://www.lxforums.com/board/signaturepics/sigpic23029_3.gif
    MY HEMI REGISTRY PAGE
    ... Do it for fun and enjoy the improved performance, but don't think you made a transaction that makes any financial sense. Use the economy numbers to torpedo the tree hugger who wants to get snooty with you, but know in your heart you did it so you could go faster.
    EXTREME's Avatar
    Oct 2005
    Flowood, MS
    Quote Originally Posted by gooeytek View Post
    Thanks man!!
    12.69 @ 109.65
