Results 1 to 7 of 7
    BrotherB's Avatar
    BrotherB is offline The Blessed Hellride
    Dec 2007
    By the lake
    Mechanic needed....
    My beater with a heater...
    My daily driver...
    My work horse...
    Has become ill and for the life of me I can not figure out what is wrong.
    Long story.... short version..
    2 months ago it broke down at work. Called a "recommended" auto shop and had it towed there. After the "diagnostic's" they told me it was a burnt valve. No biggie done my own head swaps before. Had the head gone through. Installed it, and wouldn't run. The "recommended" shop alsi said that it needed some carb work. So instead of giving them any more money it was cheaper to buy a new webber. Got the carb last week put it on... nothing. Started for and ran for about 3-4 minutes then died.
    Not sure if it's the floats or what.
    The vehicle is a 1980 Chevy LUV 4X4 with the 1.8 inline 4 cylinder.
    There is no electronics on it at all. So I'm not sure what's wrong.
    Here's a run down of what I've replaced besides the head work...
    Fuel pump...
    Cap, rotor, points, condensor, plugs...
    Brand new webber 2 barrel carb...
    all new gaskets through out....
    I've checked timing twice and have adjusted valves 3 different times, thinking it might of been a valve too tight.
    Checked for vacume leaks... plugged every possible spot that might cause a vacume leak.
    And when it runs its really rough... did a compression test and all cylinders are around 125 pounds. It's got me stumped and I'm ready to part it out and call tge wrecker... but before I get too drastic I was wondering if there is a good mobile mechanic that is knowledgeable and fairly reasonable with cost.
    Sorry for the.long winded post but I wanted to try to cover all bases.
    Bill
    2006 Dodge Magnum AWD Groups I,II and III.
    "The Blessed Hellride"
    Mods... Too much to list!! So mods can be seen http://www.lxforums.com/board/f76/5-7l-hemi-registry-00819-brotherb-94468/
    BLUEBOY455's Avatar
    BLUEBOY455 is offline If it works make it better.
    Mar 2009
    vancouver wa
    Need more info to give real help. When it dies is there spark still. Did one of those trucks this week and it had a wire broken down between the coil and distributor. The webbor adaptor had a lot of places for vacuum leaks if not installed right that could be a rough idle. Jenn and I will be at shop most of the day feel free to call for a bit of help. Sounds like a few simple problems. 360-695-6030 Dings
    Having as much fun possible making power, with good friends 11.521@ 117.83 NA /11.007 @ 123.5 MPH N2O Stock cam and heads, diablo with DINGS CMR tune, 90mm TB, 373 gears, BB 4400 TC, (costom exhaust, CAI, ported intake manifold By DINGS), larger injectors for E-85, slicks, self made N20 kit and roll bar.
    BrotherB's Avatar
    Dec 2007
    By the lake
    Quote Originally Posted by BLUEBOY455 View Post
    Yes there is spark...
    And as far as vacuum leaks, there shouldnt be any.
    Hylomar is good stuff especially when using on intakes and adapter's...
    It has to be something simple there's only three things that help make it run...
    Fuel, spark, air...
    No brolen wires on the.coil as the.coil is also new....
    It's got me stumped...
    BLUEBOY455's Avatar
    Mar 2009
    vancouver wa
    Like I said give us a jingle, we may be able to give some hints.
    Alikazam's Avatar
    Alikazam is offline Bada-BIG-Boom
    Dec 2008
    Beaverton, OR
    Is it possible the cam timing got off somehow? Just an idea
    1972 Dodge Van "Tigerlilly" - Blazing Copper/Sandstone Metallic - 360SB - N2O - 340 WHP N/A - 438 WHP N2O - 13.471 @ 97.53 mph N/A - 11.949 @ 113.33 mph N2O
    2009 Dodge Challenger SRT8 "Leelu" - TorRed - 6.1L/6spd - Vortech V3 - 500+ whp/470+ wtq - 12.66 @ 112.05 - 114.22 mph best trap so far.
    J-Z's Avatar
    J-Z
    J-Z is online now LX Guru
    May 2009
    Wow,every other mechanic would say bring it in and we'll charge you an arm and a leg,not give free tips.
    Stand up troy,stand up.
    CURRENT MODS
    100mm tb
    INTAKE MADE BY CRISS
    WHIPPLE 2.9L TWIN SCREW WITH DIRECT PORT N20 ACTION BABY
    393 BUILT BY TROY DING WITH LOVE
    Sent from My HP laptop while taking a crap.
    Alikazam's Avatar
    Dec 2008
    Beaverton, OR
    Quote Originally Posted by J-Z View Post
    I know you're exaggerating, lol, but I'm sure they would all be right up front and honest about charging you an arm and a leg. haha.
