Results 1 to 15 of 15
    10ChallSRT8's Avatar
    10ChallSRT8 is online now Enjoying his Midlife Crisis
    Mar 2011
    Spanaway, WA
    LX Harmonic Balancer Puller advice for 6.1L
    I'm gathering data for on what I need to get to do my build when I get back from deployment. Will this type of Harmonic Balancer Puller work on the 6.1L? Not sure if there are different types that would work better. I've read that I can rent one but the one linked is only 17 bucks heh. I'm looking at getting the SLP 25% UD Pulley... does it takes the place of the stock Harmonic Balancer?
    EDIT: also found a link showing 50+ different Harmonic Balancers ... quite a choice!
    SRT Max cam, SLP 25% UD Pulley, Jet 180 T-Stat, Solo X-3 catback, 3.73 Getrag, LMI fenderwell CAI, and Zeitronix ZT-2 AFR.
    Cam install by Troy Ding w/ tuning via Johan
    . Dyno 31Aug2012: 414hp/410tq _Idle Video_ Best 1/4 mile: 12.571 @ 110.7 mph
    All Mods listed at --> 6.1L Hemi Registry #1530 10ChallSRT8
    fnkychkn's Avatar
    fnkychkn is offline genuine factory cercumsized sh!tforbrain
    greasy cardboard box
    bolt grip puller (like the one in your link) won't work.
    you need one of these.
    Mar 2011
    Spanaway, WA
    Hard to tell in pic... does that have 3 claws to pull the pulley? Would this work? OTC 6667 GM/Chrysler Harmonic Balancer Puller
    fnkychkn's Avatar
    yes, 3 claws to pull the pulley and a selection of push rod lenghts for different applications.
    fnkychkn's Avatar
    Mar 2011
    Spanaway, WA
    Cool, thanks ... costs more but having the right tool is priceless
    BryGuy's Avatar
    BryGuy is offline GO SENS!!
    May 2011
    Markham, Ontario
    Don't forget a long bolt that will thread a good part of the way into the bolt hole with some sort of spacer(s) to get the pulley back on....
    300SRT rear spoiler / T Kutz Custom sill plates, ABS cover and firewall cover / emblems by Nate @ ReBadge / BT bling & catch can / braided line here & there / Red halos by the now defunct DLuxFX / Grant Revolution steering wheel w/ AMG paddle shifters & TRS300's wireless shift controller / Infinity V6 engine cover / 22" Boss 337's / Extreme Dimensions front spoiler / V6 custom tune by Overkill / JBA shorties / SOLO cat-back exhaust / SRT sways / Stoptech SS brake lines / Street Edge coilovers /LMI true CAI
    Gdragich's Avatar
    Gdragich is online now Keeping it Green with MDS!
    Mar 2009
    Arlington, WA
    Psst...nitwits have all the tools already.
    Sent from my SCH-I405 using Tapatalk
    2005 Mineral Gray AWD Hemi Registry # 1154 Comp Cams 260 cam, Blastin' Bobs 9db, Dual Flowmasters, Gibson Shorty Headers, JBA High Flow Cats, Frankentake CAI, Techco Strut Barce, Taylor Shorties, 180 thermo, 85mm TB, Flastech Halos, Predator-tuned by Diablotoona. 2008 Magnum BB R/T Hemi Registry # 1584 PPP Stage 2 Cam, JBA Shorty Headers, JBA High Flow cats, Heartthrob Exhaust, Eagle Intake, 85mm BBK TB, LMI Intake, SMF Strut Brace, lowered, Tuned by Diablotoona
    Afterhours Mopar Performance's Avatar
    Afterhours Mopar Performance is offline Formally & still NYINSTALLER
    Jan 2008
    South FLorida
    If you are not going to do it alot you can use of of these.
    for the one below you will have to put a small extention in the crank hole for 1/2 inch more length.
    8" Three-Jaw Puller
    [/SIGP][SIGPIC]
    Licensed and Insured.
    Modern Muscle 426 Built and ready to roll.
    *NYINSTALLER*
    9/10/10
    r/t- .317 60'- 1.594 1/4- 12.902
    bradenton. 10-9-10
    r/t .395 60'- 1.802 1/4 -12.890
    12.3 at pbir 2012
    Facebook: http://www.facebook.com/pages/AfterH...348401?sk=wall
    Tranmission valve body, torque converters. and blue top installs.
    contact me for all your upgrading needs.
    TheBeej418's Avatar
    TheBeej418 is offline Got a little German in me
    Jan 2008
    Nashville, TN
    Does anyone know the length of the rod on the correct puller? I went and rented the GM/Chrysler puller form O'Reilly Auto Parts when I did my install and I'll be darned if none of the rods were long enough. None were missing either so I can't blame that.
    Quote Originally Posted by Afterhours Mopar Performance View Post
    for the one below you will have to put a small extention in the crank hole for 1/2 inch more length. 8" Three-Jaw Puller
    Do you use like a socket extension?
    '06 Silver R/T with Road and Track on UAS
    alex.cecil89 is offline LX Padiwan
    May 2012
    Greensboro NC
    i just used the crank bolt to put pressure against the bolt to pull it off. backed out the bolt more and more every time i pulled the pulley off a little more and more
    '07 Brilliant Black R/T ... powdercoated 6.1, solid lifters, .015 shaved heads, mopar air intake, bbk shorty headers with full 3" catless flowmaster exhaust with super 44s, 180 therm, 22" staggered fit viper reproductions wrapped in nittos, eibach lowering springs w/ eibach adj arms and spc bushings
    SFC20 is online now RE
    Tacoma Wa
    The web site dose not list this puller for the 5.7 or 6.1. May be just an over site on their part.
    yoyo's Avatar
    yoyo is offline M42
    Dec 2009
    Everett
    [QUOTE=TheBeej418;4004865]Does anyone know the length of the rod on the correct puller? I went and rented the GM/Chrysler puller form O'Reilly Auto Parts when I did my install and I'll be darned if none of the rods were long enough. None were missing either so I can't blame that.
    The rod lengths on my Schley SCH64900 are 4", 5 3/8", 6 1/2", and 7 3/8". The 3 jaw pointed out by Afterhours Mopar Performance works as well or possibly easier. The difference is you have to move the radiator out of the way for the bigger puller.
    1FST4DR's Avatar
    1FST4DR is offline I just dont get it...
    Ft Laud.....
    Quote Originally Posted by SFC20 View Post
    5 months ago it did
    Tdola's Avatar
    Tdola is offline Done!!!!!!!
    Long Island, NY
    Dont forget about the install of the SLP 25% Underdrive pulley install.... I had to fill in the keyway with an epoxy in order for it not to leak. Also, in the directions, it says to bore the hole on the SLP pulley to a specific spec for the 6.1. Not sure if anyone else had these issues. Some people heat up the SLP pulley in a pan of oil and then slip it on too. Although, if you ever had to remove it, I would think it would be close to impossible to remove it that way though. Good Luck.
