Results 1 to 8 of 8
    onecoolmofo's Avatar
    onecoolmofo is offline I never finish anythi
    Hillsboro, OR
    Boiler plant job
    Just putting the word out there for anyone interested and qualified as I know people are looking.
    It appears there will be a Journeyman Level Boiler Plant Operator spot open at the VA Hospital in Portland. It is not entry level, you will have to have plant experience but we do about 30 days training on this plant before letting you drive by yourself.
    Veteran's get preference if they have experience. It is a Dept. of Veteran's Affair job after all.
    If you have experience and are interested shoot me a pm and I will get you info on how to apply when it is out.
    The opening is because an operator took a supervisors spot in the Vancouver plant.
    07 Magnum R/T
    Inertia Performance Heads / Spartan Max Cam 114lsa / Mopar LT's / Magnaflow Catback / Frankentake IV CAI / 180 Tstat / 6.1 injectors
    / CMR by Bob @ SVS / Edge 2800 verter / Zaino products inside and out.
    Coming soon: 3.06 gears, wavetrac, 09 RT axles and 2010 Eagle Intake
    Magatron's Avatar
    Magatron is offline 2.5L turbo B4 to 5.7L HEMI V8..Who Knew
    Dec 2008
    Beaverton, Or
    Can a journeyman Electrician operate it?
    Hillsboro, OR
    It would require some steam/boiler experience. It is a pretty extensive plant running multiple buildings. The operator also has the Chiller Plant, Fire Monitoring, Gas Monitoring, and all DDC control monitoring (which is about 76K points in itself). We also run the Vancouver campus from Portland through the DDC system at night.
    If a veteran is not picked up (special vietnam era status) and the job goes out on USAjobs.com I would encourage you to apply though, lot of times we don't find what we are looking for and smarts and personality mean a lot. Also if you are a veteran it is a good deal as for benefits and retirement/pension.
    It is step pay and I believe it start around $23.75/hr with the first raise in 6 months.
    07 Magnum R/T
    Magatron's Avatar
    Dec 2008
    Beaverton, Or
    I unfortunately couldn't afford a job at that rate unless things were desperate for me and I sold my house. The little guy is pretty expensive as it is. It really sounds like an interesting and challenging position, however. If it were closer to 35 an hour I would keep an eye on it for sure. Always looking to expand my horizons. Thanks for the info, eh?
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    No boiler experience, but tons of Hydronic and HVAC experience with hot / chilled water and all types of HVAC equipment. Unfortunately, I have to stick around for a few more years on my regular job:(
    Who's DDC controls? JCI, Siemans?
    Hillsboro, OR
    Delta Controls.
    I am the Instrumentation Controls Tech for both campuses.
    The pay for that job isn't up with union scale, but if you are a veteran the package is nice though. For instance right now I get 71 paid days off a year plus sick time.
    07 Magnum R/T
    ujokin2's Avatar
    ujokin2 is offline LX Guru
    May 2006
    Suffolk, Virginia
    Quote Originally Posted by onecoolmofo View Post
    Delta Controls.
    Ya might want to put what WG grade it is... that would help....
    I'm with the VA as well ...
    N/A ET 10.44@128
    Joy ride TT Challenger 9.71@143
    7.5L Aluminum Block 460 N/A 635RWHP\650RWTQ By Lewis Performance Machine
    Quote:
    Originally Posted by Jack SickSRT
    Bring what you got, run it and STFU!
    Hillsboro, OR
    WG-10
    Step1 :23.75
    Step2: 24.74 (after 6 months)
    Step3: 25.73 (at 2 year point)
    Step4: 26.72 (after 2 more years)
    Step5: 27.71 (after 2 more years)
    Plus and annual increase every year, normally in the 2.5 to 3% range
    07 Magnum R/T
