Results 1 to 7 of 7
    Feb 2011
    Vacaville, CA
    Can my preditor be used on another vehicle for diagnostics??
    My friend has a Jeep commander with an issue. The predator version for his is U7137 (I think). mine is U7135. I would imagine the OBD ports to be the same. Does anyone know for sure if I would be able to read/clear the codes on his vehicle? Thanks in advance.
    Apr 2006
    in a word no..
    I once plugged my U7135 into a Crossfire to see if I could read codes and it just gives an unrecognized vehicle/vin error. can't do anything.
    I'm only responsible for what I say, not for what you fail to understand.
    Feb 2006
    Columbia Ridge, OR
    That was one of the pluses of the Superchips unit. It works on my Dodge and I've used it to read and clear codes on a Chebby.
    Mar 2006
    Auburn WA
    Quote Originally Posted by Big Boy View Post
    Weird. I tried my superchips on our Ford van, no dice.
    Jan 2008
    Virginia Beach, VA
    Trinity or iTune may be able to if vehicle is supported but Predator is model spicific...
    Gunner (Mike)
    2007 Tor-Red MSRT W/ SRT group I, II & III
    LMI true CAI, MMPG 87mm TB, GTP Ported Intake Manifold, Inertia Performance Heads, FRI Tomahawk, 176* T-Stat, SLP U/D pulley, JBA Long Tubes with catted mids, Custom cat-back W/ Blastin' Bob's, PT 2800, Blue tops, Getrag W/ 3.73s and CMR tuned by Brent at DTP.
    11/11/11 11.504 @ 118.00, 1.598 60' W/ 315/35/17 NT05R DRs @ 20lbs, 93 oct pump gas, 4125lbs, and a DA of -680
    Feb 2011
    Vacaville, CA
    Ok, thanks for all the replies!
    Jun 2007
    Ft. Lauderdale
    If it is a CAN PCM, the U7135 will work.
    If it is an 05-06 model that talks on the SCI bus, you'd need a U7137 or U7134 Predator to read codes
    No harm in trying by any means.
