Results 1 to 7 of 7
    Feb 2016
    392 compression test results
    Car has 28k miles. Had the tester so figured do a test. Each time let the car crank over for good couple seconds.
    Pretty much 175 across the board.
    This good ?
    Charleston, South Carolina
    All equal is good.
    It isn't easy being GREEN
    Likes 392WLCHR liked this post
    Jan 2011
    Porter Ranch, CA
    The amount of compression isn't important. What you're looking for is that all cylinders are similar.
    2016 Charger SRT TorRed
    Stock - Best: ET 13.094, MPH 109.04 (DA 1817ft.), 60ft. (1.95 radials)
    2008 Caliber SRT4 Inferno Red - SOLD
    14.091@105.93 (2.327 60 ft.)
    MS1K v.2, MPx catted DP, K&N drop-in, NGK plugs, RT 180, Mopar hitch, new short block @ 82,000
    2007 300C SRT8 Inferno Red - SOLD
    12.77@110.71 (2.003 60 ft.)
    AFE CAI, Predator 93 CAI, Magnaflow gutted high-flow cats, Stack intake spacer, BBK 85mm TB, JET 188, Proxes 4 275/40ZR20
    Jun 2013
    Why was compression test done at 28k miles?
    Jun 2016
    Georgetown, Tx
    Because he had the tester and figured why not.
    2016 Charger Scat Pack
    LMI Intake
    3.70 gears
    Dynomax Mini Bullet Mufflers
    Active exhaust delete
    Hemifever Tuning
    Feb 2016
    Also because oil consumption heard a lot of valvetrain noise. Decided to pull the dip stick needed almost 3qt. Wasn’t sure if last oil change place did it or what. Pulled the plugs no oil on them. Did the compression test all good. However when cold start I get puff of smoke pretty good then goes right away. My cats are also shot from the 2 step
    Nov 2017
    Southern Ohio
    Sounds like bad valve seals to me....using oil and puffing smoke on cold motor all classic sign.
    Quote Originally Posted by Rockstar9528 View Post
