Page 14 of 14 FirstFirst ... 4121314
Results 196 to 210 of 210
  1. #196
    Aug 2015
    Quote Originally Posted by XenonDepot View Post
    Thanks for the clarification. Either send us a PM with your order info or an email as to what you wanted to do with the kit you got.
    Danny
    I decided to just install these, install was simple just finding a place for all the harness to tie down was a pain. I’ll probably buy some more 3M to place them down sturdier.
    Thanks Dan either way!
    Thanks XenonDepot thanked for this post
  2. #197
    Quote Originally Posted by IReCoN View Post
    Awesome! Hope you are happy with the results
    Danny
    Use our Shop by Vehicle tool to find the right lighting for your Mopar, and the most up-to-date Mopar lamp replacement guide!
    1-877-522-2701 | info@xenondepot.com
    Likes arod412 liked this post
  3. #198
    Jan 2016
    South Jersey
    Xenon.....can you please give us options in regards to LED sidemarkers!! I currently have oracles, and I'm just ready to move on to something that has been tested and proven to last .
    2016 Dodge Charger Scat pack
  4. #199
    Jul 2017
    Few pics of location.
    Sent from my SM-G920I using Tapatalk
  5. #200
    Aug 2015
    Quote Originally Posted by rcmpayne View Post
    Nice! My only issue is driver side will not lock in. See pic anyone else have this issue ? I’ve fought with this thing for well over a hour.
  6. #201
    Quote Originally Posted by arod412 View Post
    Our lighting guide does not show what type of bulbs the sidemarkers are. Can you confirm what bulb type you need and what color? I'll see what we have available.
    Looks like the pictures aren't loading :(
    This is a 9005 HID bulb correct? Have you tried to swap the blue o-ring with the one from your factory halogen bulb?
    Danny
  7. #202
    Aug 2015
    Danny
    Correct! I will try that I never thought it could be the o ring I’ll try it when I return from my trip. Thanks.
  8. #203
    It's not the actual base of the bulb. We've had some reported issues where in certain cases the rubber o-ring is too thick. Swapping it with a thinner one resolves the issue.
    Danny
  9. #204
    Jul 2017
    Danny
    Pics take 2
  10. #205
    Mar 2016
    Pittsburgh, PA
    I bought a 5000K kit from XenonDepot for my Scat Pack. I finally got it installed and here's the result:
    I know there's some variance in color temp from bulb to bulb, but that looks a little more significant than I've ever seen. I've emailed XenonDepot asking about it. I'll update here after I hear back.
    Otherwise, I've had a good experience with XenonDepot and their kit. They replaced a ballast after it arrived broken, so I'm impressed with their customer service. The kit itself is great quality and is pretty easy to install. The hardest part for me was installing the driver's side because I have the hellcat intake mod which makes it a little more difficult to remove the air box. The direct installation with PWM module is straightforward. I did have to reverse the polarity on the plug to the car harness, but that's a quick swap. I was also a little careless when drilling out one of the dust caps for the headlights and cracked it with the drill. They're made from a very brittle plastic, so you have to be very careful when drilling.
  11. #206
    Aug 2015
    Quote Originally Posted by PittPaz View Post
    B5 blue hell yeah!!! Your first three pics don’t show.
  12. #207
    Thanks for the feedback and glad to hear you have overall been happy. As for the color, I do see a slight difference as well but I would recommend allowing the HID bulbs to settle in which can take about 100 hours of usage. If there is no change after this, please contact us with new pictures via email and we'll be happy to review it and warranty it for you.
    Danny
  13. #208
    Mar 2016
    Pittsburgh, PA
    Imgur wasn't cooperating. I tried to fix it.
    Danny
    Thanks. We'll see if it changes with some use.
    Likes IReCoN liked this post
  14. #209
    Sep 2017
    Just would like to post my experience. I ordered the following item from Amazon.com PIAA 26-17395 White 9005 Platinum LED Bulb, 2 Pack (6000K 9005 (HB3) 4000Lm, 6000K, ... Amazon.com: PIAA 26-17395 White 9005 Platinum LED Bulb, 2 Pack (6000K 9005 (HB3) 4000Lm, 6000K, 25W): Automotive
    These looked very nice(see photos) but honestly the output was not able to meet the stock halogen bulb. I plan to buy HID's to get the matching light color on my front end, without losing distance lighting output.
    Travis Ochoa
    Maui Hawaii
    Likes bgipson21 liked this post
  15. #210
    Aug 2015
    HID/LED aftermarket headlight bulbs
    Quote Originally Posted by stormtrooper_scat View Post
    Travis Ochoa
    Maui Hawaii
    While those look good as you mentioned the output didn’t meet your expectations I would suggest the XeononDepot kit
