Results 1 to 9 of 9
    May 2017
    Houston, TX.
    Drive Shaft Worries ?
    I have the 2017 Challenger Hellcat automatic, stock on drag radials, should the drive shaft hold up ok or when should I start to worry about it breaking ? I don't plan to add any more power to the car (maybe) , but has anyone else broke a drive shaft just on drag radials with a stock Hellcat ? Or at what HP should I start to think about upgrading drive shaft & axles ? Info is appreciated, Thanks.
    Jul 2015
    I'm wondering the same thing.
    Thanks smokie302 thanked for this post
    May 2017
    Houston, TX.
    Quote Originally Posted by JRW114 View Post
    yeah , If necessary, I would rather replace now instead of it breaking first & maybe tearing up other stuff ?
    Thanks troper thanked for this post
    Jan 2017
    East Bay CA
    Didn't they change the ds in 16 to a stronger one because everyone was breaking the 15 shafts?
    i do know the dad shafts are hit or miss on fitment and vibration (even dampened)... g force might have one and qa1 is working on theirs.
    May 2017
    Houston, TX.
    Quote Originally Posted by Fifty View Post
    I don't know about the stronger ds but I hope they did, I hope the stock ds will handle drag radials ? I do have Auto trans. so it's a little easier on ds. Does anyone else know about the updated stock stronger ds in the 2016 & 2017 Hellcats ?
    May 2013
    If your running drag radials you should get the drive shaft. The 16 shafts are breaking as well with stock power and drag radials.
    Aug 2017
    Does this void rhe warranty? Also should you upgrade the ds only with drag tires or going to 305 or 315s as well?
    Sent from my SM-N910P using Tapatalk
    May 2017
    Houston, TX.
    Quote Originally Posted by mike929 View Post
    Warranty should be good, I've seen & read that on DR's or slicks it's likely to break stock DS when the car hooks hard enough times. I wanted that piece of mind (as much as possible ) & not tear up other stuff when & if it does break. If you have to pay for tow home, other stuff that it will tear up & buy another DS any way , it pays to go ahead & do it before hand.
    Aug 2017
    Quote Originally Posted by Badcat View Post
    Great, I was really wondering about. Being that it seems the majority of owners find the 275 lacking, this is good news. But of course check with your dealer(s) in your area. I would think you would get inconsistent messages but you never know.
