for quick reference to those of us that need to run our own wiring for the dash speakers.
with the BA dash speakers, if u look closely at the connector(straight down at the prongs) on the speaker, u will see a 1 on one side and a 2 on the other side of the the connector..
I am trying to tap into the rear subwoofer wires to get the signal for another subwoofer amp. Does anyone know what the different color wires up the subwoofer are for? Postive negative? left right ?
I know I'm reviving a long dead thread, but will my Magnum with the BA system still have the outputs for the subwoofer in the harness that I can tap into or are those wires just omitted from the connector? I want to add an external amp and sub to my factory Boston system.
On my 2008 Magnum with the BA system.
On my car there is a connector (C200) on the driver's side that connects the
electrical stuff in the dash with the rest of the car. Pins 37 and 38 are wired on the
dash side and are not populated on the car side of the connector. I believe they are
gray/brown pin 5 and dark green/brown pin 14 at the plug in the amplifier (to base
amplifier). I picked up power and ground by the battery, and the amp “on” signal
from the fuse box fuse that controls the power plug so that the amplifier is powered
anytime the accessories are powered. I twisted the signal wires (three to four twists
per inch) since they ran along with all the other wires from the front to the rear, and
didn't want to pick up some stray signals. The amplifier worked best switched for
high level input.
Related Threads
LX Forums Forum
5.2M posts
122.9K members
Since 2004
