Page 19 of 19 FirstFirst ... 9171819
Results 271 to 284 of 284
  1. #271
    Aug 2016
    What do I need to connect the chassis harness plugs to the RER radio? They don't match up to the '05 Durango. I pulled this RER from my '09 truck that got totalled.
    Sent from my hammer and chisel using Tapatalk
  2. #272
    Oct 2011
    South Jersey
    Funny that’s what I said you have to replace the two wire with the single wire. But it’s all good.
    2006 Dodge Charger R/T - 85mm Throttle Body, AFE Stage 2 CAI, 6.1 Intake Manifold, Modern Muscle Intake Adapters, 219/223 cam, 6.1 pushrods, Manley NEXTEK Valve Springs, 6.1 Timing Chain, 6.1 oil pump, Edelbrock Titech Headers, Flowmasters X pipe, Thrush 2 Chamber Mufflers, Flowmaster Resonators and tailpipes, 3200 Edge Converter, Mopar TCM, Tranzformer, Carbon Fiber Pistol Grip Shifter, 3.06, Brake Performance drilled and slotted rotors.
  3. #273
    Jul 2007
    San Antonio, Tx
    Quote Originally Posted by HoustonGlock View Post
    Do you have the lockpic adapter?
    2009 Challenger SRT8 TorRed (AKA Tori)
    SRT Max Plus cam, Ported n Polished intake manifold/Heads w/Long Tube Headers by Rich Mack, tune by Dave Katz, Cat delete, 3" exhaust w/Magnaflow mufflers 180* T-stat, catch can, Cervinis Ram Air CAI, Hurst short throw w/pistol grip shifter, Amsoil fluids
    06 Magnum R/T AWD
    1976 Corvette L82 (gave to my Son)
  4. #274
    Aug 2016
    Quote Originally Posted by HemiSilva View Post
    No, I don't. Need to start with that?
    Which model?
  5. #275
    Jul 2007
    San Antonio, Tx
    Which model?
    Here ya go...
    MYGIG ADAPTER
  6. #276
    Aug 2011
    OR & CA
    I don't know about the Durango, but the early LX's like my '06 had a low speed CANBus and the MYGIG RER's from the later vehicles ('08 and up, I think) used high speed buss and were not compatible.
    2006 MAGNUM SRT8
    Performance: Diablosport Trinity, TranZformer, LMI Hammer CAI,
    BT Catch Can (GETRAG 3.06 to be installed)
    Appearance: RK Sport Viper Hood, Drake Billet Strut Tower Brace, BT Underhood Stuff
    Audio: MyGig, Kicker Amp & Speaker Upgrades, MTX Thunderform Subwoofer
    2006 Dodge Ram 2500 Cummins Turbodiesel 4WD
  7. #277
    Apr 2013
    Quote Originally Posted by DerekZ View Post
    The lockpick adapter allows you run a high or low speed mygig unit. It's a dip switch setting on the unit, also in the instructions.
    I'm running a high speed rhr from a 2013 Durango in my 07 300. Only thing you have to watch for is how the radio mounts in the dash. Durango and Cherokee were different mounting.
    Sent from my SM-G935W8 using Tapatalk
    Thanks HoustonGlock thanked for this post
    Likes HoustonGlock liked this post
  8. #278
    Aug 2011
    OR & CA
    Quote Originally Posted by Haus View Post
    That's good. They must have updated the adapter firmware or at least added to the instructions since I put in mine about 6 years ago.
    At that time it was emphasized that you needed to have a unit that matched your car's CANBus speed. The instructions included with mine state that high speed mygig radios are not compatible.
    May be important for those buying used older setups to check on this.
  9. #279
    May 2005
    Woodstock, GA formally from L.I.
    yes Lockpick adapter can be used on high or low speed mygig units but a low speed unit is required for lx retrofits. high speed units are not compatible.
    Sent from my MHA-L29 using Tapatalk
  10. #280
    Apr 2013
    Quote Originally Posted by 300MAG View Post
    I am running a high speed mygig in my 07 (low speed). It can be done with the lockpick adapter.
  11. #281
    May 2010
    MD
    This^^^
    There's nice little dipswitch in the adapter harness that allows you to choose what speed your head unit is.
    03 Hemi Ram, 06 Charger R/T, 05 Magnum R/T
    Likes Haus liked this post
  12. #282
    Jul 2017
    Quote Originally Posted by BlackAce View Post
    No you need to change cause you won't get a signal and you have a dual wire and you need a single wire for it to work.
    If you go back a few pages I had the same issue when I stalled mine.
    Ok, for those who don't have the EVIC you don't need to get another tuner since the mygig has it built in. All you.need is a new antenna. The am/fm antenna is separate all together and does not run off the tuner.
  13. #283
    Aug 2016
    Quote Originally Posted by durangoman View Post
    Any suggestions on an antenna?
  14. #284
    Jul 2017
    I may have a extra I can sell cheap!
