Manton Pushrods
Page 3 of 11 FirstFirst 12345 ... LastLast
Results 31 to 45 of 162
  1. #31
    Feb 2006
    I tried power braking at a little higher RPM last night and overpowered my brakes into a red light. I checked my datalog and I was at 3000 rpm. It didn't feel that high! I had a 3.5 60' as a result but still beat the Mustang GT next to me :-)
    8's N/A? Been there done that
  2. #32
    San Antonio, Tx
    Hell the worst part is I now need to relearn how to launch my car with the S/C...
  3. #33
    Jan 2007
    Fort Lauderdale, FL
    Quote Originally Posted by Redfox0099 View Post
    I wish I had your problem..
    AFE CAI, SLP LM II, ZEX 100Shot, Nitrous Oulet Plate , Mopar LT's/cats,
    Inertia Motorsports Perf. Heads & Spartan Cam -Ported 6.1L Oil Pump (Installed by Matt @ Michigan Hemi Performance)
    No-ESP mod, Predator Tuned, TEIN SS Coilovers, 20" Viper Replicas (custom powder coated)
    CMR Tune by Johan @ Diablo Sport
  4. #34
    Feb 2004
    Seattle, WA
    I leave the line at 2800 rpm.
    I can only push the front tires forward on HOT drag radials, otherwise I'm just doing a brakestand.
    the 3 LX's with DR's I've run have ALL wanted the "stall until you move or spin" trick for the best 60's. that does NOT mean WOT as quickly as you can go. it still is an aggressive "roll into" it.
    the 2 that I've run with stock tires want "get the damn thing OFF idle, but roll easy into throttle once you are moving"
    2018 Jeep Grand Cherokee Trackhawk - True Blue
  5. #35
    Feb 2008
    Bell Gardens CA.
    When doing all this...T/C on or off?
  6. #36
    Phoenix, AZ
    Its funny how even with cars that should be running near identical that you get different results and also how mods affect those. So anyways, you guys can enjoy your 392s, 426s, 5.7s, etc... but us 6ers have a hard enough time getting into the low 2s for a 60ft.
    Up until recently I always had the best launches with ESP off via predator (obviously) and doing a dummy launch (mash the throttle at end of 2nd amber, beginning of 3rd). When I would hold the car at stall (any RPM, 1500, 2000, etc) it would fall flat on its face off the line and bog bad but would eventually catch up. Regardless, the car would always want to push forward hard anything above 1800RPM anyways. Well, Nathan (BritishNate) always got the opposite results and the car would always do best with a break stand stalled to about 1500.
    Recently now that I have ported and polished my throttle body and lower manifold it seems to just want to GO regardless of whether I hold it against the converter or if I just mash the throttle. It launches real hard if I break stand to about 1400 and roll into the throttle harder as I lift off the brakes (like Erik says). I am going to Speedworld saturday so lets see what a fresh tune for the cams and some porting.polishing did for the car.
    Starting over with a new Magnum RT (SRT8 Conversion)... 6.1L with SRT Max Cam, Corsa catback with chambered center pipes, Sinister Extreme dual ram intake system, SRT Suspension, silver Brembos, graphite powder coated Charger SRT wheels, frost white intake manifold (ported) and valve covers, matte black engine bay, carbon fiber engine accents, 300C SRT8 Front end, Matte White vinyl wrap, Black Ops 300-Challenger style carbon fiber hood. Project "SnoMachine" all work performed by Arizona Hemi Specialists - Plum Floored Creations, Mopar Automotive Photography
  7. #37
    Lorain Oh
    Quote Originally Posted by budoboy View Post
    The stall isn't as big an issue as learning ti (Ride) the throttle out of the hole......if you hammer it after stalling it up your done!You need to ride the throttle and maintain your stalled rpm until the car is moving well then apply throttle......maintaining the same 3000rpm you stalled with for the first few feet out of the hole without letting the rpm's drop is the trick.
    BFNY Performance
    9515 Detroit Rd,Cleveland Ohio 44102
    440-787-7235 8am- 5pm
    [email protected]
    RIP NHDave
    RIP LOU1355
  8. #38
    Lorain Oh
    Quote Originally Posted by cheeksmotorsports View Post
    when doing all this...t/c on or off?
    esp off.
  9. #39
    Lorain Oh
    Figured I'd bump this with the tracks opening next weekend.
  10. #40
    St. Louis
    When stalling should I just watch my tac and not worry about the tree or should I watch the tree and just stall till the car wants to move?
    Quote Originally Posted by JusticePete
    Even bad pub is good for business.
    In my years of business I have found that there are three truths: the customer's truth, the busness owner's truth and the truth that lies some where in the middle. No additional commentary is required nor would it would serve no purpose.
    My Pedders Experience
  11. #41
    Mar 2006
    So Cal
    That right there is pricless guys!
  12. #42
    Lorain Oh
    Quote Originally Posted by metgo View Post
    To be honest I would get a feel for the cars stall in the driveway and get used to it.Feel what the car is doing so that by the time you get to the track a quick glance at the tac if anything is all you will need.Paying attention to the tree and feeling the car is the gaol for consistancy.
  13. #43
    May 2006
    Waiting on the gravy train
    Once it moves, you're done. You will break the beam & redlight.
  14. #44
    Nov 2005
    Laceys Spring, Al
    Would this vary any with an AWD? We dont have to worry about spinning, we do have to worry about breaking stuff but I would think with AWD you could be much more aggressive with the roll in after stalling it up... I stop short of saying hammer it though in my novice runs I have made I admit that is what I did.
    2005 Dodge Magnum AWD R/T (MINE)
    2006 Chrysler Crossfire SRT-6 (Shared)
    2015 Jeep Grand Cherokee SRT (Wife's)
  15. #45
    Lorain Oh
    Quote Originally Posted by Daniel454 View Post
    Hammer it......lol.....worked well on my AWD.Stalling will help take any slop out of the driveline to keep from shocking parts.Mine had a horrible bog if I tried just off idle,stalled it would just take off.
