Results 1 to 10 of 10
    Mar 2009
    Miami,FL
    Arrington V-CAI-90 question...
    How can a CAI produce this 20hp & 23 torque for the srt's? Will it make that much with the stock TB or would I have to get the 90mm TB? Because that is pretty sick for an intake imo.
    Joseph
    FLXC Member
    Mopar CAI,Magnaflow cat-back,180 t-stat,Predator,245/40-275/40/20,demolded
    Hemi Registery #1333 http://www.lxforums.com/board/the-hemi-registry/215368-6-1l-hemi-registry-1333-blue-bullet-srt.html
    Jul 2009
    Oshkosh, WI
    2 reasons:
    1. Decent amount of taperand diameter. This means the "choke point", or smallest cross section is bigger than the TB, and short, which enables a higher air speed without the associated pumping loss.
    2. "Cobra head" style elbow. This acts as a mini plenum, giving the TB a sort of reservoir, instead of just a regular 90 pipe bend. This enhances the air speed profile around the perimeter of the TB, resulting in a higher average air speed for a given max. It is the maximum air speed that limits how much air can be moved without "choking". The more even your "velocity profile" is, the more air you can flow without crossing the velocity threshold. The cobra head elbow allows the TB to pull from all 360.
    You gotta keep in mind that moving air faster gets more in the engine, but it takes energy to move it. There is a certain air speed that makes the most power. Slower, and you loose power from lack of airflow. Higher, and all the power the extra air makes is simply wasted on accelerating the air, itself. It's all a matter of finding the majical spot in the middle.
    Hope this helps.
    Mar 2008
    Stamford, CT
    Mar 2009
    Miami,FL
    Thanx guys those 2 post did help.
    Feb 2007
    Texas
    Interesting that the C&L intake tube forms a cobra head also...always wondered why go through the expense.
    2006 Inferno Red Charger SRT8
    K-1 426
    K-1 427
    K-1 428
    SHR trans|Wavetrac&3.23s|DSS shafts
    Built by Cam
    Tuned by Sohfast94
    *Car sold, and missed, September 2013*
    Mar 2008
    Stamford, CT
    Cobra head elbows are not expensive. Check out the vendor below:
    http://intakehoses.com/Merchant2/mer...gory_Code=CHEW
    IME the cost/benefit of the Arrington CAI lies in the tapered carbon fiber intake tube which resists the transfer of excess heat from the engine bay while producing a ram air (compression and acceleration) effect as noted in the other posts.
    Dec 2005
    Arizona
    Quote Originally Posted by richierevs View Post
    I did this comparison of a cobra head vs. a 90* elbow a while ago.
    http://www.lxforums.com/board/members/richierevs/albums/pics-of-cobra-head-vs-90-elbow/
    Has anyone conducted a dyno comparison between the two?
    I, currently, have a cobra head 90 that I will incorporate into my intake system.
    When you do things right, people won't be sure you've done anything at all.
    My friends call me JONN (usually).
    Mar 2008
    Stamford, CT
    Quote Originally Posted by MAGFX View Post
    I did a quick comparison with my CSRT8 (but didn't keep the dyno sheets). In both cases the front of the intake manifold was milled and ported to match the 90mm TB, so there was no restriction once the air passed into the TB; and the tapered carbon fiber CAI was used in both tests. Check out my sig for the other mods.
    Below 3.5 K there was no difference in RWHP. However, above 3.5 K RPM there was a consistent a 18 - 20 RWHP advantage with the cobra head elbow. Due to the increase in air flow, fuel delivery above 3.5 K RPM will need to be adjusted to mitigate any lean-out conditions at WOT.
    Bottom-line: By itself the ram-air CAI with a cobra head elbow makes a difference in air flow. However, the results will vary depending on all the engine and drivetrain mods of the vehicle. In other words, results may vary.
    Dec 2005
    Arizona
    Very cool...thanks, Rich!
    Feb 2007
    Texas
    Again interesting. I lost 15 RWHP on the dyno recently with a straight 90 degree tube. Pulling it off restored the HP.
