Page 3 of 7 FirstFirst 12345 ... LastLast
Results 31 to 45 of 92
  1. #31
    Mar 2009
    Edmonds, WA
    Its generally the lifter that bites it and that takes out the cam
    Sent from my SM-G925V using Scat Pack Forums mobile app
    2008 Magnum BB R/T Hemi Registry # 1584 PPP Stage 2 Cam, JBA Shorty Headers, JBA High Flow cats, Heartthrob Exhaust, Eagle Intake, LMI Intake, MTCM, Blue Tops, ProTorque Converter, SRT Rear, Techo Strut Brace, lowered, Tuned by Diablotoona SOLD--2005 Mineral Gray AWD Hemi Registry # 1154
    For the work being performed, length is far more important than diameter :^)
  2. #32
    Mar 2018
    Quote Originally Posted by Genestealer View Post
    Just pulled the valve cover (10min job). This proves everything, worn intake cam lobe.
    Dodge Charger 5.7 cylinder misfire, worn camshaft lobe - YouTube
    Ya that's what I kinda figured. Now do i upgrade the reman block with new cam hellcat lifters 6.1 valvsprings and pushrods or do I leave it stock and hope it doesn't happen again? Block was rebuilt by mopar 05/17
  3. #33
    Jan 2018
    Quote Originally Posted by Surfer5567 View Post
    If you're just fixing the car to sell it, don't bother. If you gonna keep it, why not, i would even update to a performance camshaft for more power.
  4. #34
    Mar 2018
    So finally got the motor pulled and low and behold it was the cylinder 5 intake lifter went bad and flattened the cam sadly. So I bought a reman mopar motor off craigslist, brand new, for a 2010 300c. Everything is going together well except the mds solenoids. The plugs aren't the same. Anyone know if there is a conversion harness or new clips I can use??? What do I do?
  5. #35
    Sep 2016
    could always delete MDS, not a big advocate of that generally, but it may be the easiest/most supported solution to that problem. Not sure if there is a harness or anything somewhere.
  6. #36
    Mar 2018
    I've thought about going that route but it might be more expensive right now. I'm just trying to get it back on the road.
  7. #37
    Nov 2017
    Pittsburgh, PA
    Can you just swap the solenoids from the original engine?
  8. #38
    Mar 2018
    They're virtually impossible to get out without breaking them
    Thanks pursuitlx thanked for this post
  9. #39
    Nov 2014
    Spray some lube on them, I used two paint can openers and lightly wedged one side at a time wiggling them and twisting them gently. Might not work for you but it did for me.
  10. #40
    Mar 2018
    Central Indiana
    Waiting for the follow up........
    In the meantime, I was told by Dodge mechanic that the camshafts in the HEMI's are notoriously SOFT compound. The wrong oil can cause a sticky lifter and it rounds the cam lobes almost instantly.
    Sucks.
    He also mentioned that's why the replacement OEM camshaft is around $60 brand new... but the lifter sets, for each side, is about $500 EACH! And since you HAVE to replace the lifters with the cam, the low priced cam is the weak link here.
    With labor, that equates to roughly $1700-$1800 dealership job for cam/lifter swap. :( Hence, why I was eager to say GoodBye to the '07 Charger I started with.
    2013 Charger R/T
    Road & Track Package
    Bone stock... for now!
  11. #41
    Jun 2008
    Well crap! I my 09 RT started this today, under load it hesitated and check engine light started flashing and threw the p0305 code. Idle is fine it only held back when I was WOT then started shaking the car, dropped my speed and the shaking stopped but the light stayed on. I was hoping it would be a simple fix like a coil pack now I am not to happy
  12. #42
    Nov 2014
    Start with swapping the coil pack and checking spark plugs. Then move onto pulling valve covers and visual inspection while turning over by hand. Then leak down/compresson test.
  13. #43
    Jun 2008
    So Im guessing worst case scenario seeing how if the spring fails it causes wear on the cam if I have read correctly. Might as well go with a better cam right? Spartan Eagle plus would be a drop in and improvement over stock right?
  14. #44
    Nov 2014
    I’ll let someone else chime in if spring failure would lead to a cam lobe being flattened but I don’t think so myself, just doesn’t seem like it would. A spring failure would most likely still allow the lifter and cam to rotate in my mind. Cam damage is from lifter failure.
  15. #45
    Jun 2008
    If it literally is just spring failure would that be something I could do myself or is it like everything else on this car that requires special tools?
