Results 1 to 11 of 11
    Los Angeles, Ca
    Where is the crankshaft position sensor?
    My 05 RT was missing, stalling, and hard to start. CEL and BAS/ESP light came on. Got code P0335, crankshaft position sensor. Dealer has the sensor but I can't find it on the engine.
    Help
    Center of the LX Universe
    Passenger side. Goes into the engine block.
    Assuming you have a RWD..... that means you've got to move the starter out of the way. The crank position sensor is behind it.
    2005 AWD Magnum RT. FRI Econo Heads & FRI Sidewinder, JBA Shorties, JBA/HHP hi-flow catted mids, stock SRT8 cat-back, C&L CAI. 12.645@108.18 - RETIRED
    2015 Chrysler 300S - Daily Driver
    Phoenix
    oops! wrong one, Jr.
    - Click above for my HEMI Registry page -
    Quote Originally Posted by Junior View Post
    I believe it's right behind the Thermostat housing, where the coolant hose mounts to the block.
    Just to the aft from there, I think you'll see it.
    That's the Cam position sensor Junior......
    the op's looking for the crank position sensor.
    It'll be found exactly where I posted earlier. Passenger side of the block, just head of the tranny, behind the starter.
    Welland ON
    cam sensor is on the pass side of the block, near the pan line. not sure if you have to remove the starter, guess it depends on how limber you are.
    http://www.lxforums.com/board/signaturepics/sigpic18566_2.gif
    Phoenix
    Quote Originally Posted by Token View Post
    Doops! Thanks for the correction. I weren't paying attention.
    welcome to my world...... oh look.... A bunny!
    Los Angeles, Ca
    Thanks Token, Junior, and Fargo59.
    Now if I had just stayed by the computer for a few minutes I might have got it replaced today. But no, I had to take a nap that lasted too long and now I have to get my girl friend to ferry the dogs to the vet for boarding since I'm going to Hawaii tomorrow for a week.
    Have a good weekend, I know I will.
    Los Angeles, Ca
    Just to follow up, it was the crankshaft sensor. Pretty simple repair unless you get an idiot parts man like I did who ordered a camshaft sensor for me when they had the crankshaft sensor in stock and I had to go to the dealer three times, and wait four days to finally get the right sensor.
    Now to put on the hood struts I had to get for the originals that failed and then look into why my Bluetooth connection has now stopped working.
    Feb 2008
    Eastern Shore of Maryland
    If it's the cam position sensor read this thread http://www.lxforums.com/board/showthread.php?t=133957 and if it's the crank position sensor read the same thread and he said its behind the starter.
    2010 Challenger SRT /M6 with an ARI 440 rebuilt by Charlie's Machine, Apache heads Ported by Craig of Thitek, Ported 6.1 Intake by Modern Muscle, 90mm TB by ARI, TTi 1-7/8" Long Tubes, Zoomers 3" Exhaust, LMI 4" CAI, Trinity Tuner, BC Racing Suspension, Zeitronix Wideband, Hotchkis Sway Bars and Tuned by Brent @ DTP Racing.
    North Texas
    Put the bunny back in the box.
    2012 Dodge Charger
    PB 1/8 run: 7.92 @ 86.92 * 1.76 60' on street tires with DA at 1786 - All Stock
    Current mods:
    Custom tune by Lxmodguy, Stage II VB, Corsa Extreme Exhaust and LMI true CAI
