Results 1 to 4 of 4
    Feb 2015
    Another tire size question.
    Hello, I recently picked up an 05 300c. It has srt 20"wheels, I don't know backpacking or offset or anything.
    The rear has 275/45, the front has 235/45. The front just look too short compared to the back. A tire calculator says the rears are 29.7, and the fronts are 28.3. What size can i run that won't be too wide, but will be closer in height, without rubbing or anything? Maybe I'm being picky, but it looks a little off to me, the way it is.
    Sent from my LG-H918 using Tapatalk
    Mar 2010
    Atlanta
    245/45 is OEM size on front...though I seem to remember the rear being 255/45.
    275/40 is the widest that still has the same diameter, though not sure that will fit front without rubbing.
    Personally I would go 245/45 all around so you can rotate front to back.
    Oct 2010
    Orlando, Fl
    245/45 will match up the front with the 275/40 in the rear
    LMI True 4" CAI - Tranzformer V2 - Trinity - QTP Cut Outs
    Killer Glass - BT Catch Can & Underhood Bling - Drake Strut Bar
    20x9.5, 20x10.5 Brass Monkey Hellcat Reps - KW Adjustable Springs
    Feb 2015
    Thanks for the replies guys
